[Qgis-user] Is there way to print out a layered PDF-document?
Järnefelt Jouko Jouko.Jarnefelt at tampere.fi
Fri Mar 21 00:02:08 PDT 2014
Hey all.
I have a simple question for which I haven’t been able to find answer. Is there way to print out a layered PDF-document?
Thanks for your help!
Jouko
City of Tampere
Department of Land use and Planning
Finland
Lähettäjä: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] Puolesta ELHOA
Lähetetty: 21. maaliskuuta 2014 0:41
Vastaanottaja: Carol Kraemer
Kopio: Qgis List
Aihe: Re: [Qgis-user] How to darken a .sid layer?
Thanks Carol,
I was able to darken my .sid layer using the method you suggested.  Turned out pretty good.
Mike K
Sent from my iPhone
On Mar 19, 2014, at 4:43 PM, Carol Kraemer <cakraemer at northrivergeographic.com<mailto:cakraemer at northrivergeographic.com>> wrote:
Mike,
When I was playing with the SID I have, I was able to use a combination of tools under the Color Rendering section to darken and enhance the image. For example, I adjusted Brightness and Contrast to bring out the colors. I've attached a before and after to show the difference.
Hope that helps!
-Carol
Carol Kraemer
North River Geographic Systems, Inc
http://www.northrivergeographic.com<http://www.northrivergeographic.com/>
404.431.0125 cakraemer at northrivergeographic.com<mailto:cakraemer at northrivergeographic.com>
On Wed, Mar 19, 2014 at 4:23 PM, ELHOA <tmike.elhoa at comcast.net<mailto:tmike.elhoa at comcast.net>> wrote:
Hello Carol,
Yes on my attempted method.
I'm trying to darken the photo, (.sid), so I can get more contrast with other layers which are overlaid on top of it; roads, parcels, rivers, etc.
Sent from my iPhone
On Mar 19, 2014, at 3:26 PM, Carol Kraemer <cakraemer at northrivergeographic.com<mailto:cakraemer at northrivergeographic.com>> wrote:
Hello Mike,
You've been using the Layer Properties > Style tab to adjust the image display? I'm playing with a SID right now and have found a couple ways to "darken" the image but it might be different than what you are hoping to accomplish. What are you wanting to do specifically?
-Carol
Carol Kraemer
On Wed, Mar 19, 2014 at 3:16 PM, Mike Keelan <tmike.elhoa at comcast.net<mailto:tmike.elhoa at comcast.net>> wrote:
Hello list,
Can anyone suggest how I would darken (overall) a .sid file?  The available parameters in the properties menu seems not to do the job?  Is it even possible?
I'm using Qgis 2.0.1 and windows 8
Thanks,
Mike K
<ELHOA Logo7.jpg>
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-user
<after.png>
<before.png>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140321/948da473/attachment.html>
