[Qgis-user] Export a vector shapefile to XYZ
Lens Paul
paul.lens at gmx.com
Fri Mar 21 01:01:12 PDT 2014
Hello Lester,
I tried converting a 3D point shapefile using "save layer as" +
GEOMETRY=AS_XYZ (still using QGIS 1.8).
It didn't work but I do not have much time to try again.
Joined to this mail, you'll find a table with some information about the
conversion of 3D GIS/CAD Data.
It's a rough outline, very incomplete. It helps me finding conversion
"routes".
Take care, there may be mistakes.
Perhaps this file could be completed by other QGIS/GRASS user's,
experienced in 3D conversions?
Hope this helps,
Paul
Le 20/03/2014 12:45, Lester Anderson a écrit :
> Hello,
> Is it possible to export a shapefile into XYZ from QGIS? It is partly
> possible via the GMT option (save layer as) but not readily useable.
> Cheers
> Lester
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140321/60cda1b7/attachment.html>
Type: application/vnd.oasis.opendocument.spreadsheet
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140321/60cda1b7/attachment.ods>
