[Qgis-user] QGIS Plugin to open and parse xml metadata
Horst Düster
horst.duester at kappasys.ch
Mon Mar 24 10:04:38 PDT 2014
substitute filename with self.filename than it should work
All the best
Horst Düster
Am 24.03.2014 17:45, schrieb Suryo Miles:
> I make plugin in QGIS to open and read XML file, then parse it and show
> scale map from it, its a big xml file and line with scale information have
> format like this
> <gmd:denominator><gco:Integer>ScaleValue</gco:Integer></gmd:denominator>
> and i try code like this to open xml file and then parse it:
> from PyQt4 import QtCore, QtGuifrom ui_latih import Ui_latih# create
> the dialog for zoom to point
> class latihDialog(QtGui.QDialog):
> def __init__(self):
> QtGui.QDialog.__init__(self)
> # Set up the user interface from Designer.
> self.ui = Ui_latih()
> self.ui.setupUi(self)
> cariButton = self.ui.btnCari
> QtCore.QObject.connect(cariButton, QtCore.SIGNAL('clicked()'),self.cari)
> def cari(self, event=None):
> #open dialog
> filename = QtGui.QFileDialog.getOpenFileName(self, 'Open File', '*.xml')
> self.ui.lineFile.setText(filename)
> #call text
> self.isiDataFile(filename)
> def isiDataFile(self, nmfile):
> #open with read mode
> teksFile = open(nmfile, 'r').read()
> self.ui.textFile.setText(teksFile)
> import xml.etree.ElementTree as ET
> tree = ET.parse(filename)
> doc = tree.getroot()
> for elem in doc.findall('Default_Config/gmd:denominator'):
> x = elem.tag, elem.text
> self.ui.lineSkala.setText(x)
> for elem in doc.findall('Default_Config/gmd:MD_Format'):
> y = elem.tag, elem.text
> self.ui.lineFitur.setText(y)
> I try using Element Tree to parse and show ScaleValue in LineEdit because
> its integrated in python, but i have error message like this :
> NameError: name 'filename' is not defined
> i am really newbie in python and xml parser, can i pass the xml location
> from open xml code to
> tree = ET.parse( )
> because i plan to open more than one xml file and scale in one and another
> xml file have different value as well
> Can Someone help me?
> Qgis-user mailing list
Dr. Horst Düster
Managing Director
Sourcepole AG - Linux & Open Source Solutions
Weberstrasse 5, 8004 Zürich, Switzerland
Tel: +41 (0)44 440 77 11
Direkt: +41 (0)44 515 67 70
horst.duester at sourcepole.ch http://www.sourcepole.ch
www.sourcepole.ch/kurse - Das Kursangebot Frühjahr 2014
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140324/76cb5760/attachment.html>
