[Qgis-user] QGIS EPANET Integration for hydraulic simulation
Vincent Picavet vincent.ml at oslandia.com
Tue Mar 25 13:12:05 PDT 2014
Hello,
> From Barcelona (Spain) are working to comunicate EPA-NET, EPA-SWMM &
> HEC-RAS with GIS (QGIS, gvSIG and others)
> This tool uses PostGIS!
> More details: http://www.giswater.org/
Yes, we saw the project. Since it is Java-based, it was not really adequate
for a good integration with QGIS.
We worked on QGIS Processing SWMM integration too, but it is not ready yet.
All this work can use any QGIS data source, hence PostgreSQL/PostGIS of
course.
What could be interesting though is collaborating on a water distribution
network model to "standardize" it.
There are a few initiatives already in that field, like in the qwat project
with Denis Rouzaud, which are really complementary to the simulation work.
We intend to work towards that goal in the future.
Do you have a full dataset for EPANET that you could provide and share, so
that we include some test/example dataset with the Processing plugin ? That
would be great.
Vincent
Le mardi 25 mars 2014 20:40:03, Carlos López PSIG a écrit :
> Hello,
> Best regards,
> * <http://www.psig.es> *
> *Carlos López Quintanilla*
> www.psig.es
> carlos.lopez at psig.es
> +34 699.680.261
> 2014-03-25 20:16 GMT+01:00 Vincent Picavet <vincent.ml at oslandia.com>:
> > Hello,
> > A short notice to say that we just released a first version of the
> > qgis-epanet
> > plugin for QGIS.
> > It is a plugin integrating EPANET into QGIS. EPANET is a public domain
> > water
> > distribution network simulation tool originally developped by the
> > American EPA.
> > The plugin is integrated into QGIS Processing and lets you run
> > simulations within QGIS and visualize the results. As it is integrated
> > into Processing, you can use it as a building block for more complex
> > processing and simulations.
> > More information here :
> > http://www.oslandia.com/qgis-plugin-for-water-management-en.html
> > And there is a demo video :
> > https://vimeo.com/87754967#at=105
> > The plugin is hosted on GitHub, do not hesitate to test and comment.
> > https://github.com/Oslandia/qgis-epanet
> > This work has been funded by the European Union, and we thank a lot GIS
> > Apavil
> > from Romania.
> > Vincent
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
