[Qgis-user] lidar visualization in qgis
    antonio valanzano
    anvalanz at gmail.com
    Wed Mar 26 01:07:58 PDT 2014
Dear  Vincent
thanks for the interest in this discussion.
I am not a developer but a qgis user and my intention is only to discuss
with other users about those minimal functionalities so that somone who is
going to develop a plugin/add core functions has a shared idea of what qgis
users expect.
So I am not  able to discuss about technical questions of what kind of
library should be used.
However I agree with you about adding the support for PostgreSQL PointCloud
support since this is already an available datasource.
Antonio Valanzano
2014-03-25 21:25 GMT+01:00 Vincent Picavet <vincent.ml at oslandia.com>:
> Hello,
> Le mardi 25 mars 2014 21:08:24, antonio valanzano a écrit :
> > I would like to start a discussion about the minimal functionalities
> that a
> > new lidar plugin or a  core function  should present.
> > Based on my experience the minimal requirements are:
> > - to read data in LAS format
> > - to visualize points based on classification or intensity
> > - to allow the filtering of points based on classification
> > - to allow the selection of points with spatial relationship with other
> > layers
> > - to export filtered points or selected points in LAS format
> + PostgreSQL PointCloud support
> Do you plan any PDAL and/or PCL integration into the core or Processing ?
> Maybe pointclouds is more for a second step with data processing
> capabilities.
> http://www.pdal.io/
> http://pointclouds.org/
> Do you have any idea on the 3D visualization aspect ? It is often a strong
> use
> case.
> Vincent
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140326/57f77ced/attachment.html>
