[Qgis-user] relation between the value of $area and the CRS	(lat/long coordinates)
    Manuel Campagnolo
    mlc at isa.ulisboa.pt
    Wed Mar 26 03:52:44 PDT 2014
I have a question about calculating areas for polygon layers when
coordinates are geographic (e.g. CRS=WGS84). In the example below I used
a map of the US  (a MultiPolygon of the 50 States)
1): The layer and project CRS were WGS84 (EPSG:4326) -> The expression
$area in field calculator returned a small value (1116.7), which I
believe is obtained from lat/long coordinates (as if the map projection
was Plate Carré) ;
2): I did change the Project CRS to a projected CRS
(USA_Contiguous_Albers_Equal_Area_Conic) and I used $area again to
compute the area -> the result was identical;
3) I reset the Project CRS to WGS84 and I created a 3rd field using
again  $area -> this time around, the result was 9'475'180'617'431.81
(m2) -- !! (it is the same Layer and Project CRS than 1).
If I reproject my Layer to USA_Contiguous_Albers_Equal_Area_Conic and
then compute $area the result is 9'264'554'959'451.9 as expected.
I would like to understand was is the rationale for $area (and other
Geometry methods) in relation to the Layer and Project CRS when the
coordinates are lat/long.
Thanks,
Manuel
_________________
Manuel Campagnolo
http://math.isa.utl.pt/~mlc/
