[Qgis-user] Problem opening .GDB (v 10.1) using QGIS
    Eric Goddard
    egoddard1010 at gmail.com
    Thu Mar 27 10:06:56 PDT 2014
I have gdal built with FileGDB support and I was unable to open the
geodatabase; QGIS gave an invalid datasource error. Arcpy reports that
it is indeed a version 10/10.1 database though. Using
ogrinfo -al FWA_LINEAR_BOUNDARIES_SP.gdb
reports that it was successfully opened:
INFO: Open of `FWA_LINEAR_BOUNDARIES_SP.gdb'
      using driver `FileGDB' successful.
However, it should have also printed detailed information about the
feature classes in the geodatabase, which it didn't. Not sure what is
going on in the gdb. I was able to open it with ArcMap (checked the
version with arcpy).
On Thu, Mar 27, 2014 at 12:05 PM, Clifford Snow <clifford at snowandsnow.us> wrote:
> On Thu, Mar 27, 2014 at 8:32 AM, cdp <cdaponte at synergyaspen.ca> wrote:
>> The data is supposed to be an Esri file geodatabase created with ArcGIS
>> 10.1.
>> The data  is stream network data from the BC provincial government and can
>> be found at the following FTP location if anyone wants to try it out on
>> their end (no login info required)
>> ftp.geobc.gov.bc.ca/pub/outgoing/FWA_Public
>> There you will find 4 zipped files. Download the smallest of them and let
>> me
>> know what you find. that should be
>> FWA_LINEAR_BOUNDARIES_SP.gdb.zip
> ogrinfo -al just reports:
> I'm able to open other FileGDBs. I wonder if someone with ArcGIS can open
> this file?
> Clifford
> @osm_seattle
> osm_seattle.snowandsnow.us
> OpenStreetMap: Maps with a human touch
> Qgis-user mailing list
