[Qgis-user] Problem opening .GDB (v 10.1) using QGIS
Saulteau Don
sault.don at gmail.com
Thu Mar 27 14:28:28 PDT 2014
This is because something changed in ArcGIS >= 10.x on how they apply the
BC Albers projection (EPSG:3005).
Those datasets now have to be opened in ArcGIS and the projection has to be
"Defined" as BC Albers, because it's using PCS_Albers (projection name),
gdal sees this as a "custom projection" so it won't list any layers.
This is annoying, because BC Albers and PCS_Albers, besides the difference
in name, have the exact same parameters.
I've tried to contact the GeoBC folks when this came up, but didn't get a
response. Simply asking them to please assign the BC Albers projection to
the DRA and the FWA so that we can access it using the FileGDB API via GDAL
(or QGIS!).
I posted in the ArcGIS forums to discover this [0].
[0]
http://forums.arcgis.com/threads/100486-Is-BC_Albers-being-incorrectly-identified-as-PCS_Albers-It-s-corrupting-my-data
On Thu, Mar 27, 2014 at 11:23 AM, Randal Hale <
rjhale at northrivergeographic.com> wrote:
> I was able to open FWA_Watershed_Boundaries_SP.gdb in ArcGIS 10.2 - but
> not in QGIS 2.2.
> OGRinfo would open it - but I couldn't seem to get a list of layers.
> Randy
> Randal Hale, GISP
> North River Geographic Systems, Inchttp://www.northrivergeographic.com423.653.3611 rjhale at northrivergeographic.com
> twitter:rjhalehttp://about.me/rjhale
> On 03/27/2014 01:05 PM, Clifford Snow wrote:
> On Thu, Mar 27, 2014 at 8:32 AM, cdp <cdaponte at synergyaspen.ca> wrote:
>> The data is supposed to be an Esri file geodatabase created with ArcGIS
>> 10.1.
>> The data is stream network data from the BC provincial government and can
>> be found at the following FTP location if anyone wants to try it out on
>> their end (no login info required)
>> ftp.geobc.gov.bc.ca/pub/outgoing/FWA_Public
>> There you will find 4 zipped files. Download the smallest of them and let
>> me
>> know what you find. that should be
>> FWA_LINEAR_BOUNDARIES_SP.gdb.zip
> ogrinfo -al just reports:
> INFO: Open of `FWA_LINEAR_BOUNDARIES_SP.gdb'
> using driver `FileGDB' successful.
> I'm able to open other FileGDBs. I wonder if someone with ArcGIS can
> open this file?
> Clifford
> @osm_seattle
> osm_seattle.snowandsnow.us
> OpenStreetMap: Maps with a human touch
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140327/17a8abb4/attachment.html>
