[Qgis-user] Atlas generation - Rule based renderer on two different layers??
    Alexandre Neto
    senhor.neto at gmail.com
    Fri Mar 28 01:04:18 PDT 2014
Yes you can. check the end of this post.
http://nathanw.net/2013/12/02/waiting-for-qgis-22-highlighting-current-atlas-feature/
Alexandre Neto
Em 28/03/2014 07:56, "Pietro Rossin" <pierigis at gmail.com> escreveu:
> Hello people
> I'm using the atlas generator and I'm able to use a rule based renderer on
> the Atlas feature showed by the filter: $id = $atlasfeatureid
> I'm wondering if it is possible to render the symbology of a second layer
> using a distance criterion
> I know postgis can query a feature layer by distance with a second layer
> with st_dwithin(g1,g2,d).
> Is it possible to make something similar on the fly using the $geometry of
> the second layer and $atlasgeometry as the selector by distance of the
> feature to be rendered?
> bie
> pietro
> http://osgeo-org.1560.x6.nabble.com/Atlas-generation-Rule-based-renderer-on-two-different-layers-tp5131712.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140328/9fe6dc59/attachment.html>
