[Qgis-user] Atlas generation - Rule based renderer on two different layers??
    Pietro Rossin
    pierigis at gmail.com
    Fri Mar 28 06:03:15 PDT 2014
Hello
If I try to apply a ruled style with this statements I cannot achieve
expected result
IE apply a style to feature layer if the centroid of the atlas feature is
in the feature to be styled
intersects(centroid($atlasgeometry), $geometry )
within(centroid($atlasgeometry), $geometry )
contains($geometry,centroid($atlasgeometry) )
Where is my mistake?
bie
2014-03-28 10:03 GMT+01:00 Pietro Rossin <pierigis at gmail.com>:
> Thank you Alexandre
> Yess!!!
> I get rid of the problem just after this posting.. And indeed the solution
> was as written on the end of Nathan post..
> Now i was playing with label rules but without success...
> I have two polygon layers, each feature of the first one can perfectly
> contain one or more features of the second (this last is the layer for the
> atlas generation), but sometimes the atlas feature can slightly exceed the
> containing polygon of the first layer
> I want the label to appear for the first layer only for the feature that
> contains the atlas feature and not for the surrounding ones...
> So I wrote this statement:
> CASE WHEN contains($geometry , centroid($atlasgeometry)) THEN my label END
> But it doesn't work...
> 2014-03-28 9:06 GMT+01:00 Alexandre Neto [via OSGeo.org] <[hidden email]<http://user/SendEmail.jtp?type=node&node=5131732&i=0>
>> Yes you can. check the end of this post.
>> http://nathanw.net/2013/12/02/waiting-for-qgis-22-highlighting-current-atlas-feature/
>> Alexandre Neto
>> Em 28/03/2014 07:56, "Pietro Rossin" <[hidden email]<http://user/SendEmail.jtp?type=node&node=5131715&i=0>>
>> escreveu:
>>> Hello people
>>> I'm using the atlas generator and I'm able to use a rule based renderer
>>> on
>>> the Atlas feature showed by the filter: $id = $atlasfeatureid
>>> I'm wondering if it is possible to render the symbology of a second layer
>>> using a distance criterion
>>> I know postgis can query a feature layer by distance with a second layer
>>> with st_dwithin(g1,g2,d).
>>> Is it possible to make something similar on the fly using the $geometry
>>> of
>>> the second layer and $atlasgeometry as the selector by distance of the
>>> feature to be rendered?
>>> bie
>>> pietro
>>> View this message in context:
>>> http://osgeo-org.1560.x6.nabble.com/Atlas-generation-Rule-based-renderer-on-two-different-layers-tp5131712.html
>>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>>> Qgis-user mailing list
>>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5131715&i=1>
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5131715&i=2>
>>  If you reply to this email, your message will be added to the
>> discussion below:
>> http://osgeo-org.1560.x6.nabble.com/Atlas-generation-Rule-based-renderer-on-two-different-layers-tp5131712p5131715.html
>>  To unsubscribe from Atlas generation - Rule based renderer on two
>> different layers??, click here.
>> NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: Re: Atlas generation - Rule based renderer
> on two different layers??<http://osgeo-org.1560.x6.nabble.com/Atlas-generation-Rule-based-renderer-on-two-different-layers-tp5131712p5131732.html>
> Sent from the Quantum GIS - User mailing list archive<http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html>at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140328/39ac8907/attachment.html>
