[Qgis-user] Qgis slow in retrieving PGsql data.
Luca Lanteri
mescal72 at gmail.com
Sat Mar 29 13:06:34 PDT 2014
Which version of PostGIS are you using ?
You have to check to have at least select grants to the geometry_columns
table (in postgis 1.5) or view (in postgis 2.0) in public schema.
If you can't access to this table qgis spends a lot of time in order to
scan all geometries of all layer.
with PostGIS < 2.0 you also have to manually register you layer into the
geometry_columns table
regards
Luca
2014-03-28 13:38 GMT+01:00 Nico Alberti <n8 at langhirano.it>:
> Hi everybody. I am rather new to both technnologies (Qgis and PGsql data)
> so sorry if the question is lame. When I try to connect to a PGsql
> database, everything goes fine; layers are correctly listed and I can see
> their geometry type and primary keys. However the "add layer" [1] is
> disabled: on the lower left part of QGis there is a message saying that
> QGis is busy scanning the "the_geom" column, and this is taking a lot of
> time (there are several huge datasets in that db).
> After the scan is over, eventually I am not able to load most of the
> datasets. A message states they are invalid and cannot be loaded.
> I know I am not giving you a lot of hints. The errors are quite generic.
> However when I try to connect to another PGsql database (one that I can
> fully manage) everything goes fine. Could the dataset be corrupted in some
> strange way, could they lack something that forces QGis to scan the entire
> geometry data?
> Every suggestion would be greatly appreciated. Thank you in advance.
> [1] messages are in Italian, as you can guess. The actual English message
> is probably different.
> Ciao
> Nico
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140329/6554a4fb/attachment.html>
