[Qgis-user] Changing symbolsize in Printcomposer-legend
Andreas Neumann
a.neumann at carto.net
Fri May 23 03:19:44 PDT 2014
Hi Lene,
Without knowing how you specified the symbol size, my assumption is that
you used map units for the symbol size.
Unfortunately, with map units, there is no way to influence the way the
symbol scales in the print composer. This is a missing feature/limitation.
If you specified the symbol size in mm it would probably look ok in the
print composer legend.
I don't even know how one could solve this issue - a mapping between map
units and mm, solely for the scope of the printed legend or legend in
QGIS WMS server?
Andreas
Am 23.05.2014 07:34, schrieb Lene Fischer:
> Hi
> In my lecture I´ve just got a question which I can´t find the solution for. Therefore I now try on the list -As part of teaching to use the mailinglist for help.
> We use 2.2, Have made a categorized layer. Made a Printcomposer in A3 with map and legend. But the symbols looks too small. We can change fonts. Tried to change Symbol Height/Width, but it only change the spacing.
> How can we change symbolsize?
> Regards
> Lene Fischer
> Qgis-user mailing list
