[Qgis-user] QGIS v2.6
Luigi Pirelli luipir at gmail.com
Sat Nov 1 03:42:13 PDT 2014
main blocker should be solved... do you refer to a specific issue? can
you point it to check it's status?
regards, Luigi Pirelli
On 1 November 2014 10:42, Lester Anderson <arctica1963 at gmail.com> wrote:
> Hi
> Just wanted to get an idea of when the next version (2.6) is due for
> release?
> The last versions of QGIS 2, 2.2 and 2.4 all had a runtime error on the
> 64-bit version (non-fatal), so had to revert to the 32-bit ones to avoid;
> has this issue on 64-bit been resolved?
> Cheers
> Lester
> Qgis-user mailing list
