[Qgis-user] QGIS v2.6
Lester Anderson
arctica1963 at gmail.com
Sat Nov 1 04:50:17 PDT 2014
Hello,
No specific issue, I beliewve the error code was R6034 and just happened
starting up QGIS (64-bit) , but after clicking OK on the message, the
program loaded fine. I had seen the same issue since v2.0 and was still
there at 2.4
I use the 32-bit version to avoid this runtime "error" but just wanted to
see if progress had been made to address it; this was a known issue as I
understand.
Lester
On 1 November 2014 10:42, Luigi Pirelli <luipir at gmail.com> wrote:
> main blocker should be solved... do you refer to a specific issue? can
> you point it to check it's status?
> regards, Luigi Pirelli
> On 1 November 2014 10:42, Lester Anderson <arctica1963 at gmail.com> wrote:
> > Hi
> > Just wanted to get an idea of when the next version (2.6) is due for
> > release?
> > The last versions of QGIS 2, 2.2 and 2.4 all had a runtime error on the
> > 64-bit version (non-fatal), so had to revert to the 32-bit ones to avoid;
> > has this issue on 64-bit been resolved?
> > Cheers
> > Lester
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141101/a206b4d5/attachment.html>
