[Qgis-user] QGIS curve looking lines not viewable
Vincent Picavet
vincent.ml at oslandia.com
Mon Nov 3 02:00:06 PST 2014
Hello Andreas,
> Curves (circular arcs) are not yet supported in QGIS.
> There is an ongoing development to implement curves for display and
> editing, but in its first incarnation it will only support Postgis data
> sources. There may also be support for GML/WFS (but I am not sure). The
> plan is to release it in either 2.8 or 2.10.
Would'nt this typically be the kind of change which would require a QEP ?
It would be great to have one before the actual implementation, so that
potential design problems or impacts on other parts of the code (or plugins)
are detected.
Thanks,
Vincent
> If you have interest in curve support in other data formats (Oracle, SQL
> server, dxf, etc.) you are very welcome to support/sponsor the effort.
> Andreas
> On 31.10.2014 05:35, Explorer wrote:
> > Hi,
> > New to QGIS and trying to make it work with our Oracle data.
> > Currently
> > using QGIS v2.4
> > When viewing some polylines(Oracle datatype 2002) which are looking like
> > curves, I don't see that displayed in QGIS.
> > The rendering is like this and I did disable the "Simplify geometry" in
> > layer properties' rendering menu.
> > <http://osgeo-org.1560.x6.nabble.com/file/n5170519/QGIS_Missing_Curve1.pn
> > g>
> > *Curved line visible from the same Oracle data viewed in MapGuide Open
> > Source*
> > <http://osgeo-org.1560.x6.nabble.com/file/n5170519/MGOS_PolyLine_As_Curve
> > _Visible.png>
> > Any suggestions or assistance in rendering?
> > Thanks for your help.
> > View this message in context:
> > http://osgeo-org.1560.x6.nabble.com/QGIS-curve-looking-lines-not-viewabl
> > e-tp5170519.html Sent from the Quantum GIS - User mailing list archive at
> > Nabble.com. _______________________________________________
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
