[Qgis-user] QGIS curve looking lines not viewable
Andreas Neumann a.neumann at carto.net
Mon Nov 3 05:31:05 PST 2014
Yes - I think this should be accompanied with a QEP. Marco Hugentobler
is working on this project. As the project started in parallel with the
QEP introduction process a QEP wasn't requested as part of the process.
I do hope that Marco finds the time though to provide a QEP.
Andreas
On 03.11.2014 11:00, Vincent Picavet wrote:
> Hello Andreas,
>> Curves (circular arcs) are not yet supported in QGIS.
>> There is an ongoing development to implement curves for display and
>> editing, but in its first incarnation it will only support Postgis data
>> sources. There may also be support for GML/WFS (but I am not sure). The
>> plan is to release it in either 2.8 or 2.10.
> Would'nt this typically be the kind of change which would require a QEP ?
> It would be great to have one before the actual implementation, so that
> potential design problems or impacts on other parts of the code (or plugins)
> are detected.
> Thanks,
> Vincent
>> If you have interest in curve support in other data formats (Oracle, SQL
>> server, dxf, etc.) you are very welcome to support/sponsor the effort.
>> Andreas
>> On 31.10.2014 05:35, Explorer wrote:
>>> Hi,
>>>      New to QGIS and trying to make it work with our Oracle data.
>>>      Currently
>>> using QGIS v2.4
>>> When viewing some polylines(Oracle datatype 2002) which are looking like
>>> curves, I don't see that displayed in QGIS.
>>> The rendering is like this and I did disable the "Simplify geometry" in
>>> layer properties' rendering menu.
>>> <http://osgeo-org.1560.x6.nabble.com/file/n5170519/QGIS_Missing_Curve1.pn
>>> g>
>>> *Curved line visible from the same Oracle data viewed in MapGuide Open
>>> Source*
>>> <http://osgeo-org.1560.x6.nabble.com/file/n5170519/MGOS_PolyLine_As_Curve
>>> _Visible.png>
>>> Any suggestions or assistance in rendering?
>>> Thanks for your help.
>>> View this message in context:
>>> http://osgeo-org.1560.x6.nabble.com/QGIS-curve-looking-lines-not-viewabl
>>> e-tp5170519.html Sent from the Quantum GIS - User mailing list archive at
>>> Nabble.com. _______________________________________________
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
