[Qgis-user] Excel Prep to how one line per location
Frank van Baar
frank at van-baar.com
Tue Nov 4 00:00:15 PST 2014
Hi Sasa,
Would use excel to do the manipulation:
· Add 2 columns to original sheet with rownumber & number of locations
· Create second sheet that recreates a new list based on lookups/index formulas
· Copy second sheet as values into CSV file
Have created simple example file (attached).
Hope it works.
Frank
Van: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] Namens Sasa Sullivan
Verzonden: 03 November 2014 20:20
Aan: qgis-user at lists.osgeo.org
Onderwerp: [Qgis-user] Excel Prep to how one line per location
Hi All,
I need to prep an Excel spreadsheet. Thousands of names and each name with multiple locations (some with as few as 3 and others with over 30 locations). Is there a way to make a line item for the name (which is only listed once initially) based on each location?
So If I have Bob Smith row with columns that show his 12 locations can I do something to automate my spreadsheet to show Bob Smith with each location on a separate line? There are also other columns that need to be duplicated but those would remain the same with each line item, only the location would be made a new line item. Thanks much in advance
Best Regards,
Sasa
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141104/d3dab5f8/attachment.html>
Type: application/vnd.openxmlformats-officedocument.spreadsheetml.sheet
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141104/d3dab5f8/attachment.xlsx>
