[Qgis-user] Python script to iterate through attributes and then refresh the canvas - doesn't show any map....
Joris Hintjens
jorishin at gmail.com
Tue Nov 4 02:27:19 PST 2014
Why not use atlas generation in the print composer?
Seems to me this corresponds with your „what i’m trying to achieve”
grts
Joris
Op 4-nov.-2014, om 09:14 heeft Frank van Baar <frank at van-baar.com> het volgende geschreven:
> Hi,
> Am completely stuck with a QGIS project in Python and tried everything but nothing seems to work. The python script does work as such BUT the canvas never shows the map and therefor the exported maps are empty….
> What I’m trying to achieve:
> · Create a Python script that iterates through a series of ca. 2500 polygons based on attribute value, zoom to layer extend and save the canvas for each attribute as an image file.
> · I then use the image files in other documents
> The issue is that while manually I get the canvas to reload and display the map, this doesn’t happen when running the python script. Have tried couple of ways:
> 1. Don’t load the project each time and just change the filter
> 2. Add sleep timers to give the canvas time to refresh etc.
> 3. Tried different QGIS versions (2.2, 2.4 & 2.6 on Win 64x)
> But all to no avail…. Hope somebody’s got a great idea how to solve it.
> Regards,
> Frank
> Python code:
> # File location & specifications
> PROJECTPATH = 'C:/Users/Frank/Documents /Targetting/Kaarten/'
> PROJECTFILE = 'C:/Users/Frank/Documents /Targetting/TargettingkaartV26qgs.qgs'
> EXTSNAPSHOTS = '.jpg'
> EXTSNAPSHOTS2 = '.png'
> SUFFIX = '65Plus_v1'
> last_id = 1
> while last_id < 5:
> # Clear map canvas
> QgsMapLayerRegistry.instance().removeAllMapLayers()
> qgis.utils.iface.mapCanvas().refresh()
> # Open QGIS project
> QgsProject.instance().setFileName(PROJECTFILE)
> QgsProject.instance().read()
> time.sleep(30)
> canvas = qgis.utils.iface.mapCanvas()
> acl = canvas.layer(0)
> qgis.utils.iface.mapCanvas().layer(0).selectAll()
> selection = 'RijNo = ' + str(last_id)
> acl.setSubsetString( selection )
> acl.triggerRepaint
> canvas.layer(1).triggerRepaint
> time.sleep(5)
> qgis.utils.iface.setActiveLayer(acl)
> # Zoom in and out to refresh potential issues with OpenLayer
> canvas.zoomByFactor(3)
> canvas.zoomByFactor(0.5)
> qgis.utils.iface.zoomToActiveLayer()
> time.sleep(10)
> # Save project
> p=QgsProject.instance()
> p.setFileName(PROJECTFILE)
> p.write()
> # Save content of map canvas as image
> p = str(last_id) + 'kaart_'
> qgis.utils.iface.mapCanvas().saveAsImage(PROJECTPATH+ p + SUFFIX + EXTSNAPSHOTS)
> last_id = last_id +1
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141104/be6f1a34/attachment.html>
