[Qgis-user] edit spatialite with db manager
Ziegler Stefan
Stefan.Ziegler at bd.so.ch
Tue Nov 4 05:05:25 PST 2014
Thanks for the clarification.
Stefan
> -----Ursprüngliche Nachricht-----
> Von: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] Im
> Auftrag von Saber Razmjooei
> Gesendet: Dienstag, 4. November 2014 10:11
> An: qgis-user at lists.osgeo.org
> Betreff: Re: [Qgis-user] edit spatialite with db manager
> It is SQLite limitation!!:
> http://hub.qgis.org/issues/2423
> Cheers,
> Saber
> -----Original Message-----
> From: qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Ziegler Stefan
> Sent: 04 November 2014 09:04
> To: 'qgis-user at lists.osgeo.org'
> Subject: [Qgis-user] edit spatialite with db manager
> Hi
> I'm trying to e.g. rename a column of a spatialite layer with db manager.
> But in the "Table properties" window the "Edit Column" and "Delete Column"
> buttons are greyed out. Did I miss some depencies or something like that?
> I'm on QGIS master and Ubuntu 14.04.
> regards
> Stefan
> Freundliche Grüsse
> Stefan Ziegler
> Kantonsgeometer
> Amt für Geoinformation
> Amtliche Vermessung
> Rötistrasse 4
> 4500 Solothurn
> Telefon +41 32 627 75 96
> Telefax +41 32 627 75 98
> stefan.ziegler at bd.so.ch
> http://www.so.ch
> Qgis-user mailing list
> This email and any files transmitted with it are confidential and intended solely for the
> use of the individual or entity to whom they are addressed.
> If you have received this email in error please notify the system manager. This
> message contains confidential information and is intended only for the individual
> named. If you are not the named addressee you should not disseminate, distribute or
> copy this e-mail. Please notify the sender immediately by e-mail if you have received
> this e-mail by mistake and delete this e-mail from your system. If you are not the
> intended recipient you are notified that disclosing, copying, distributing or taking any
> action in reliance on the contents of this information is strictly prohibited.
> Whilst reasonable care has been taken to avoid virus transmission, no responsibility for
> viruses is taken and it is your responsibility to carry out such checks as you feel
> appropriate.
> If this email contains a quote or offer to sell products, carry out work or perform
> services then our standard terms and conditions (which can be found at
> http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Ter
> ms%20and%20Conditions.pdf shall apply unless explicitly stated otherwise.
> Saber Razmjooei and Peter Wells trading as Lutra Consulting.
