[Qgis-user] Android Camera App with compass bearing
    Andreas Neumann
    a.neumann at carto.net
    Tue Nov  4 13:37:34 PST 2014
I have DSLR (Nikon) and a separate GPS logging device from Solmeta
(http://www.solmeta.com/) - so if you can also use a DSLR in your
project, the Solmeta tagger is really excellent and writes everything
directly into the image metadata. It is also a tracking device and
records your positions at regular time interval, no matter if you are
taking pictures or not.
Just wanted to make you aware of this. The compass/clino is probably a
more precise than on a Smartphone.
Andreas
On 04.11.2014 22:17, Alex Mandel wrote:
> On 11/04/2014 04:55 AM, Zoltan Szecsei wrote:
>> Hi,
>> I need to do a field trip and take some photos.
>> I've been googling around, but cannot find an app that will burn both
>> GPS position _and compass bearing_ into either the image, or just the
>> exif data for that image.
>> Anyone got any experience in this need?
>> Thanks & regards,
>> Zoltan
> Maybe, http://geopaparazzi.github.io/geopaparazzi/
> "georeferenced and orientated pictures"
> And now my long rant before I remembered the above link...
> GPS data is an on/off toggle on most Android devices. Bearing does
> appear possible according to the exif specs, but in practice is rare.
> http://www.sno.phy.queensu.ca/~phil/exiftool/TagNames/GPS.html
> However I don't see any obvious apps for telling the phone you want to
> capture that. I'm also not sure all phones are capable of calculating
> bearing when not moving.
> So my suggested work around would be a GPS Logging application of which
> there are several. Then you can pull the bearing calculation out after
> the fact, if it was while moving.
> If stationary, you might need to write your own app which lets users
> indicate which way they were facing when taking a picture. For someone
> who's made an Android application I don't think this is hard.
> http://developer.android.com/guide/topics/sensors/sensors_overview.html
> Indicates all version of Android support the Magentic sensor.
> This example shows how to get the bearing from the API
> https://www.codeofaninja.com/2013/08/android-compass-code-example.html
> So GPS+Orientation+Camera should be all required.
> Kinda busts my GPS logging idea, since the bearing information comes
> from a different sensor than the GPS it won't be in the NMEA strings
> even if you captured them.
> Thanks,
> Alex
> Qgis-user mailing list
