[Qgis-user] Android Camera App with compass bearing
Lene Fischer
lfi at ign.ku.dk
Wed Nov 5 02:17:32 PST 2014
GPS Essentials - App
Regards
Lene
-----Oprindelig meddelelse-----
Fra: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] På vegne af Zoltan Szecsei
Sendt: 5. november 2014 07:02
Til: tech at wildintellect.com; qgis-user at lists.osgeo.org
Emne: Re: [Qgis-user] Android Camera App with compass bearing
Hi Alex/All,
Thanks for the thoughts - my comments interspersed with your.
Kind regards,
Zoltan
On 2014/11/04 23:17, Alex Mandel wrote:
> On 11/04/2014 04:55 AM, Zoltan Szecsei wrote:
>> Hi,
>> I need to do a field trip and take some photos.
>> I've been googling around, but cannot find an app that will burn both
>> GPS position _and compass bearing_ into either the image, or just the
>> exif data for that image.
>> Anyone got any experience in this need?
>> Thanks & regards,
>> Zoltan
> Maybe, http://geopaparazzi.github.io/geopaparazzi/
> "georeferenced and orientated pictures"
> And now my long rant before I remembered the above link...
I manually downloaded the latest version (newer than that on Play Store) and it still does not record bearing - even though the app does have a bearing tool.
I checked the website and recording bearing into EXIF is not even on the developer's long wish-list I have emailed the developer, with a hope to at least get it onto the wish-list.
> GPS data is an on/off toggle on most Android devices. Bearing does
> appear possible according to the exif specs, but in practice is rare.
> http://www.sno.phy.queensu.ca/~phil/exiftool/TagNames/GPS.html
Yes, I checked that last night too - TAGs 0x0017 and 0x0018 relate to bearing info.
> However I don't see any obvious apps for telling the phone you want to
> capture that. I'm also not sure all phones are capable of calculating
> bearing when not moving.
> So my suggested work around would be a GPS Logging application of
> which there are several. Then you can pull the bearing calculation out
> after the fact, if it was while moving.
Sigh, nope.
(In my kind of) Field trip data collection (& photography) often involves driving to a feature, leaning out the car window and taking a snap-shot, so recording moving direction will not help at all.
Note that bearing accuracy is NOT that critical, it needs only to be reasonably indicative.
> If stationary, you might need to write your own app which lets users
> indicate which way they were facing when taking a picture. For someone
> who's made an Android application I don't think this is hard.
> http://developer.android.com/guide/topics/sensors/sensors_overview.htm
> l Indicates all version of Android support the Magentic sensor.
> This example shows how to get the bearing from the API
> https://www.codeofaninja.com/2013/08/android-compass-code-example.html
> So GPS+Orientation+Camera should be all required.
Yep, true, but the purpose of this thread is to see if this wheel has already been invented :-)
> Kinda busts my GPS logging idea, since the bearing information comes
> from a different sensor than the GPS it won't be in the NMEA strings
> even if you captured them.
What? You not 'hard core' enough to intercept the NMEA stream and insert "bearing-on-the-fly" by back-calculating the incoming coords?
(Just pulling your leg - thanks for your interest in this topic :-) )
> Thanks,
> Alex
Zoltan Szecsei PrGISc [PGP0031]
Geograph (Pty) Ltd.
GIS and Photogrammetric Services
P.O. Box 7, Muizenberg 7950, South Africa.
Mobile: +27-83-6004028
Fax: +27-86-6115323 www.geograph.co.za
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
