[Qgis-user] R: Android Camera App with compass bearing
Randal Hale
rjhale at northrivergeographic.com
Wed Nov 5 08:06:22 PST 2014
I've got an android phone running cyanogenmod and geopaparazzi....it's
taking pics but like you I'm having a hard time finding them....
I exported the project to /storage/emulated/0 but I don't see the pic.....
Randy
On 11/05/2014 10:47 AM, AlpImage wrote:
> Hi
> As I have both sw installed in my phone, i shot a pic and I tested
> these 2 sw, reading the exif data with an online reader:
> Geopaparazzi:
> GPS
> GPS Latitude Ref North
> GPS Latitude 45.543404 degrees
> GPS Longitude Ref East
> GPS Longitude 8.072008 degrees
> GPS Altitude 419 m
> GPS Time Stamp 15:13:20
> GPS Img Direction 187.56
> GPS Date Stamp 2014:11:05
> GPS Essentials:
> GPS
> GPS Latitude 45.543367 degrees
> GPS Longitude 8.072114 degrees
> GPS Altitude Ref Above Sea Level
> GPS Altitude 368.3999938 m
> GPS Speed Ref km/h
> GPS Speed 0.071999998
> The only problem is where to find images in the phone directories…
> Ciao
> Emanuele
> *Da:*qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] *Per conto di *Randal Hale
> *Inviato:* mercoledì 5 novembre 2014 14:57
> *A:* qgis-user at lists.osgeo.org; zoltans at geograph.co.za
> *Oggetto:* Re: [Qgis-user] Android Camera App with compass bearing
> Hopefully this isn't going too off topic - so last year found me in
> the Caribbean working on an addressing project.
> I ended up using the Fulcrum app (not free) but it's really really
> good. I used it in conjunction with QGIS and PostGIS. Everything is
> stored in the "cloud" and you can download it in just about any format.
> Take a look at this:
> http://fulcrumapp.com/blog/viewing-photo-metadata/ it seems as though
> it now is collecting direction (I need to go test this).
> Randy
> On 11/05/2014 08:39 AM, Zoltan Szecsei wrote:
> Hi,
> Thanks for the thought - but see orange text below: Does not write
> bearing into EXIF fields.
> Regards,
> Zoltan
> On 2014/11/05 12:17, Lene Fischer wrote:
> GPS Essentials - App
> Regards
> Lene
> -----Oprindelig meddelelse-----
> Fra:qgis-user-bounces at lists.osgeo.org <mailto:qgis-user-bounces at lists.osgeo.org> [mailto:qgis-user-bounces at lists.osgeo.org] På vegne af Zoltan Szecsei
> Sendt: 5. november 2014 07:02
> Til:tech at wildintellect.com <mailto:tech at wildintellect.com>;qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
> Emne: Re: [Qgis-user] Android Camera App with compass bearing
> Hi Alex/All,
> Thanks for the thoughts - my comments interspersed with your.
> Kind regards,
> Zoltan
> On 2014/11/04 23:17, Alex Mandel wrote:
> On 11/04/2014 04:55 AM, Zoltan Szecsei wrote:
> Hi,
> I need to do a field trip and take some photos.
> I've been googling around, but cannot find an app that will burn both
> GPS position _and compass bearing_ into either the image, or just the
> exif data for that image.
> Anyone got any experience in this need?
> Thanks & regards,
> Zoltan
> Maybe,http://geopaparazzi.github.io/geopaparazzi/
> "georeferenced and orientated pictures"
> And now my long rant before I remembered the above link...
> *I manually downloaded the latest version (newer than that on Play Store) and it still does not record bearing* - even though the app does have a bearing tool.
> I checked the website and recording bearing into EXIF is not even on the developer's long wish-list I have emailed the developer, with a hope to at least get it onto the wish-list.
> GPS data is an on/off toggle on most Android devices. Bearing does
> appear possible according to the exif specs, but in practice is rare.
> http://www.sno.phy.queensu.ca/~phil/exiftool/TagNames/GPS.html <http://www.sno.phy.queensu.ca/%7Ephil/exiftool/TagNames/GPS.html>
> Yes, I checked that last night too - TAGs 0x0017 and 0x0018 relate to bearing info.
> However I don't see any obvious apps for telling the phone you want to
> capture that. I'm also not sure all phones are capable of calculating
> bearing when not moving.
> So my suggested work around would be a GPS Logging application of
> which there are several. Then you can pull the bearing calculation out
> after the fact, if it was while moving.
> Sigh, nope.
> (In my kind of) Field trip data collection (& photography) often involves driving to a feature, leaning out the car window and taking a snap-shot, so recording moving direction will not help at all.
> Note that bearing accuracy is NOT that critical, it needs only to be reasonably indicative.
> If stationary, you might need to write your own app which lets users
> indicate which way they were facing when taking a picture. For someone
> who's made an Android application I don't think this is hard.
> http://developer.android.com/guide/topics/sensors/sensors_overview.htm
> l Indicates all version of Android support the Magentic sensor.
> This example shows how to get the bearing from the API
> https://www.codeofaninja.com/2013/08/android-compass-code-example.html
> So GPS+Orientation+Camera should be all required.
> Yep, true, but the purpose of this thread is to see if this wheel has already been invented :-)
> Kinda busts my GPS logging idea, since the bearing information comes
> from a different sensor than the GPS it won't be in the NMEA strings
> even if you captured them.
> What? You not 'hard core' enough to intercept the NMEA stream and insert "bearing-on-the-fly" by back-calculating the incoming coords?
> (Just pulling your leg - thanks for your interest in this topic :-) )
> Thanks,
> Alex
> Zoltan Szecsei PrGISc [PGP0031]
> Geograph (Pty) Ltd.
> GIS and Photogrammetric Services
> P.O. Box 7, Muizenberg 7950, South Africa.
> Mobile: +27-83-6004028
> Fax: +27-86-6115323www.geograph.co.za <http://www.geograph.co.za>
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> Randal Hale
> North River Geographic Systems, Inc
> http://www.northrivergeographic.com
> 423.653.3611rjhale at northrivergeographic.com <mailto:rjhale at northrivergeographic.com>
> twitter:rjhalehttp://about.me/rjhale
> http://www.northrivergeographic.com/spatial-connect
Randal Hale
423.653.3611 rjhale at northrivergeographic.com
twitter:rjhale http://about.me/rjhale
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141105/11c7780f/attachment.html>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141105/11c7780f/attachment.jpe>
