[Qgis-user] Python error message version 2.6 mac os x
Emiliano Manzo emiliano.manzo at ethoikos.it
Thu Nov 13 02:28:53 PST 2014
is anybody knows why when i use version 2.6 i received most of the time this message?
After i can use normally QGIS but anytime i import or try to use some plug in i received one message like this.
I use mac os 10.9.2
Thank you
Emiliano
Errore durante l'esecuzione di codice Python:
  File "/Users/emilianomanzo/.qgis2/python/plugins/undoPropertiesChanges/undopropertieschanges.py", line 267, in currentLayerChanges
    if self.undo[layer.id()].isEmpty():
KeyError: u'Db_APO_13_100_dic201320141113112339992'
Versione Python:
2.7.8 (v2.7.8:ee879c0ffa11, Jun 29 2014, 21:07:35)
[GCC 4.2.1 (Apple Inc. build 5666) (dot 3)]
Versione di QGIS:
2.6.0-Brighton Brighton,
Percorso Python: ['/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing', '/Users/emilianomanzo/.qgis2/python/plugins/sextante_animove', '/Users/emilianomanzo/.qgis2/python/plugins/processinglwgeomprovider', '/Users/emilianomanzo/.qgis2/python/plugins/GeoCoding', '/Applications/QGIS.app/Contents/MacOS/../Resources/python', u'/Users/emilianomanzo/.qgis2/python', u'/Users/emilianomanzo/.qgis2/python/plugins', '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins', '/Library/Frameworks/SQLite3.framework/Versions/B/Python/2.7', '/Library/Frameworks/GEOS.framework/Versions/3/Python/2.7', '/Library/Python/2.7/site-packages/numpy-override', '/Library/Python/2.7/site-packages/matplotlib-override', '/Library/Frameworks/GDAL.framework/Versions/1.11/Python/2.7/site-packages', '/Library/Frameworks/cairo.framework/Versions/1/Python/2.7', '/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip', '/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7', '/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin', '/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac', '/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages', '/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk', '/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old', '/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload', '/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages', '/Library/Python/2.7/site-packages', '/Library/Python/2.7/site-packages/PIL', '/Users/emilianomanzo/.qgis2/python/plugins/MetaSearch/ext-libs', '/usr/share/qgis/python', '~/.qgis/python', '.', '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools']
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141113/5a49b393/attachment.html>
