[Qgis-user] Python error message version 2.6 mac os x
Enrico Ferreguti enricofer at gmail.com
Thu Nov 13 04:20:01 PST 2014
I am the plugin developer and I realized that issue happens upgrading from
chugiak to brighton.
I found that for some reasons the currentLayerChanged signal is now emitted
before the layersAdded signal.
I'm studying a patch to handle this...
Thanks
2014-11-13 11:32 GMT+01:00 Matthias Kuhn <matthias.kuhn at gmx.ch>:
> Hi Emiliano,
> This comes from a plugin. Please file a bug for the plugin
> undoPropertiesChanges.
> https://github.com/enricofer/undoPropertiesChanges/issues
> Regards,
> Matthias
> On 13.11.2014 11:28, Emiliano Manzo wrote:
> > Hi,
> > is anybody knows why when i use version 2.6 i received most of the
> > time this message?
> > After i can use normally QGIS but anytime i import or try to use some
> > plug in i received one message like this.
> > I use mac os 10.9.2
> > Thank you
> > Emiliano
> > Errore durante l'esecuzione di codice Python:
> > Traceback (most recent call last):
> >   File
> "/Users/emilianomanzo/.qgis2/python/plugins/undoPropertiesChanges/undopropertieschanges.py",
> line 267, in currentLayerChanges
> >     if self.undo[layer.id()].isEmpty():
> > KeyError: u'Db_APO_13_100_dic201320141113112339992'
> > Versione Python:
> > 2.7.8 (v2.7.8:ee879c0ffa11, Jun 29 2014, 21:07:35)
> > [GCC 4.2.1 (Apple Inc. build 5666) (dot 3)]
> > Versione di QGIS:
> > 2.6.0-Brighton Brighton,
> > Percorso Python:
> ['/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing',
> > '/Users/emilianomanzo/.qgis2/python/plugins/sextante_animove',
> > '/Users/emilianomanzo/.qgis2/python/plugins/processinglwgeomprovider',
> > '/Users/emilianomanzo/.qgis2/python/plugins/GeoCoding',
> > '/Applications/QGIS.app/Contents/MacOS/../Resources/python',
> > u'/Users/emilianomanzo/.qgis2/python',
> > u'/Users/emilianomanzo/.qgis2/python/plugins',
> > '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins',
> > '/Library/Frameworks/SQLite3.framework/Versions/B/Python/2.7',
> > '/Library/Frameworks/GEOS.framework/Versions/3/Python/2.7',
> > '/Library/Python/2.7/site-packages/numpy-override',
> > '/Library/Python/2.7/site-packages/matplotlib-override',
> '/Library/Frameworks/GDAL.framework/Versions/1.11/Python/2.7/site-packages',
> > '/Library/Frameworks/cairo.framework/Versions/1/Python/2.7',
> > '/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip',
> > '/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7',
> '/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin',
> '/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac',
> '/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages',
> > '/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk',
> '/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old',
> '/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload',
> '/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages',
> > '/Library/Python/2.7/site-packages',
> > '/Library/Python/2.7/site-packages/PIL',
> > '/Users/emilianomanzo/.qgis2/python/plugins/MetaSearch/ext-libs',
> > '/usr/share/qgis/python', '~/.qgis/python', '.',
> > '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools']
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> Help getting QGIS to the next level of quality before November 15!
> http://blog.vitu.ch/10102014-1046/crowdfunding-initiative-automated-testing
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141113/785543d7/attachment.html>
