[Qgis-user] Raster postGIS problema visualizar en QGIS
Juan Miguel Requena
juanmimullor at gmail.com
Thu Nov 13 05:45:32 PST 2014
Hello, some information more, I can visualize shapes from the same data
base.
Thank you.
Juanmi
2014-11-13 14:42 GMT+01:00 Juan Miguel Requena <juanmimullor at gmail.com>:
> Hello again, now I have a new problem. I connect into the data base from
> other pc without problems (via DB Manager plugin) but when I want to
> visualize the raster I can not. However, I can see the info and the table
> of the file but not the preliminar view.
> Any idea?? thank in advance.
> Juanmi.
> 2014-11-13 10:46 GMT+01:00 Juan Miguel Requena <juanmimullor at gmail.com>:
>> Hello Michael, thank you very much for your reply. My problem has been
>> solved. Indeed, I was trying to import the postGIS raster from the wrong
>> way, i.e., 'Add PostGIS layer', and when I load it from DB Manager plugin
>> there is no problem, it was very easy but it was my first time. Thank you
>> again.
>> Best regards.
>> Juanmi.
>> 2014-11-13 4:35 GMT+01:00 Michael Treglia <mtreglia at gmail.com>:
>>> Hi Juan,
>>> To display a PostGIS Raster in QGIS, I think you need to use the
>>> Database Manager plugin ("DB Manager"). If you have it installed/activated,
>>> you would access it from the "Database" tab in the menu bar at top. (I'm
>>> on QGIS 2.6 and 2.4, but I'd imagine its the same for 2.0).
>>> Is that what you're using to open the PostGIS Raster? Or were you trying
>>> to just use the normal "Add PostGIS layer" method?
>>> If that's not it, try to give more details of the steps youre taking to
>>> access the PostGIS layer in QGIS.
>>> Hope that helps,
>>> Mike
>>> On Wed, Nov 12, 2014 at 3:45 PM, Juan Miguel Requena <
>>> juanmimullor at gmail.com> wrote:
>>>> Hello Alexandre, sorry.
>>>> I have used the postGIS command 'raster2pgsql' to import a geotiff file
>>>> into a postgres data base.The process was successfully finished. Both
>>>> columns 'rid' and 'rast' were successfully created but when I connect QGIS
>>>> 2.0 to the data base and load the table, the software is unable to
>>>> recognize the data type and the geometry type, so that I can not visualize
>>>> the file and the attribute table has not the rast column.
>>>> Thank you in advance for your help
>>>> Juanmi
>>>> El 12 de noviembre de 2014, 20:51, Alexandre Neto <
>>>> senhor.neto at gmail.com> escribió:
>>>> Hello Juan, can I ask you to write your question in English?
>>>>> Thanks,
>>>>> Alexandre Neto
>>>>> Em 12/11/2014 16:25, "Juan Miguel Requena" <juanmimullor at gmail.com>
>>>>> escreveu:
>>>>>> Hola, estoy utilizando el comando raster2pgsql de postGIS para
>>>>>> importar un archivo geotif a una base de datos (postgresql). Todo el
>>>>>> proceso lo ejecuta correctamente. Crea los campos 'rid' y 'rast' bien. Pero
>>>>>> al conectarme a la base de datos con QGIS, la tabla postgres
>>>>>> correspondiente viene como 'Tipo de dato' : Nada y 'Tipo espacial' :
>>>>>> Ninguna geometría. Cuando añado el archivo y visualizo la tabla de
>>>>>> atributos solo existe el campo 'rid' pero no el 'rast'.
>>>>>> Alguien puede echarme un mano, muchas gracias por adelantado.
>>>>>> Juanmi.
>>>>>> _______________________________________________
>>>>>> Qgis-user mailing list
>>>>>> Qgis-user at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141113/54d7bb82/attachment.html>
