[Qgis-user] Loading ESRI .mdb geodatabase
Lester Anderson
arctica1963 at gmail.com
Mon Nov 24 05:14:18 PST 2014
No problem Felipe. Still cannot figure out how to get QGIS to read the .mdb
file. It is an Arc 10 version I know, but that should not be a problem.
Even tried just drag-and-drop on the view screen area and still got an
error saying it was unrecognised.
Cheers
On 24 November 2014 at 12:09, Filipe Dias <filipesdias at gmail.com> wrote:
> Sorry, I misread what you wrote.
> On Mon, Nov 24, 2014 at 12:06 PM, Filipe Dias <filipesdias at gmail.com>
> wrote:
>> Hi
>> I mean:
>> Press Add vector layer and on "Source type" press "Database". On
>> "Database type" select "ESRI Personal Geodatabase"
>> Cheers
>> On Mon, Nov 24, 2014 at 11:58 AM, Lester Anderson <arctica1963 at gmail.com>
>> wrote:
>>> Hello Filipe,
>>> I could not find an option in QGIS 2.6 a way of getting the database
>>> option to work
>>> eg. data in c:\test\esri_geodatabase\file.mdb
>>> Create a new OGR Database connection
>>> Type = ESRI Personal GeoDatabase
>>> Name = MDB1
>>> Host = C:\test\ESRI_Geodatabase
>>> Database = file.mdb
>>> Port = empty
>>> Usename = empty
>>> Password = empty
>>> Generates an error "Unable to initialise ODBC connection to DSN for
>>> DRIVER= Microsoft Access Driver (*.mdb); DBQ=PGeo:file.mdb,
>>> [Microsoft][OBDC Driver Manager] Data source name not found and no default
>>> driver specified"
>>> The "Open an OGR Supported Vector Layer" shows that ESRI Personal
>>> Geodatabase is an option under file formats. so it is there to use. Not
>>> sure how to get this working.
>>> Is there a clear tutorial guide that wouldm cover this issue?
>>> Cheers
>>> Lester
>>> On 24 November 2014 at 10:06, Filipe Dias <filipesdias at gmail.com> wrote:
>>>> Hi,
>>>> Have you tried Add layer -> Source type - "Database"?
>>>> On Mon, Nov 24, 2014 at 10:03 AM, Lester Anderson <
>>>> arctica1963 at gmail.com> wrote:
>>>>> Hello,
>>>>> I have been trying to load an ESRI (ARcGIS 10) .mdb geodatabase but
>>>>> cannot seem to get it to recognise it as a ESRI personal geodatabase file.
>>>>> Tried using add vector layer -> file -> ESRI Personal geodatabase
>>>>> format)
>>>>> and also as a directory, both seem to fail to recognise the format.
>>>>> C:\Program Files\QGIS Brighton\bin\gdalplugins\ogr_FileGDB.dll -
>>>>> checked the plugin
>>>>> Not sure what I am doing wrong here (2.6 windows 64-bit)
>>>>> Cheers
>>>>> Lester
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141124/b2f551c2/attachment.html>
