[Qgis-user] unable to open the QGIS Tab
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Tue Nov 25 22:24:44 PST 2014
Sorry,
If you install 2.4, your old QGIS 1.8 shortcuts are not always removed.  You can delete them.  To open QGIS, go to start - osgeo4w - qgis2.4. If you can't find any shortcuts in your menu, try reinstalling QGIS.  What install are you using?
Is this what you are looking for?
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
Le 2014-11-26 01:06, "Agrawal, Dinesh (NSN - IN/Kolkata) [via OSGeo.org]	" <ml-node+s1560n5174952h73 at n6.nabble.com> a écrit :
Hi
I think you are not getting my exact problem, I mean to say, after installing the QGIS, I found two icon over my laptop desktop.
1.Quantum GIS Browser (1.8.0)
2.
Quantum GIS Desktop (1.8.0)
When I am double click over these icon nothing is happening, normally on other laptop one blank page open.
I know 4 .tab file is required to open the map in one location.
Dinesh Agrawal
Transmission O&M NSN Kolkata
+919804801421
On Behalf Of ext Nicolas Cadieux
Sent: Wednesday, November 26, 2014 11:21 AM
To: [hidden email]
Subject: Re: [Qgis-user] unable to open the QGIS Tab
Unlike most file formats, a .tab file is actually 4 files with 4 different extensions (see below).  They must all be copied at the same place in the computer (same directory) if you want to open the .tab.
Make sure you have all 4 files.  If all you have is the .tab, nothing will work.  Could this be the problem?
http://en.m.wikipedia.org/wiki/MapInfo_TAB_format
"So the basic file set for viewing data and its graphic representation in vector form within MapInfo Professional requires a minimum of four files, normally the *.TAB, *.MAP, *.DAT and *.ID. If there is only textual information
 with no graphic objects, then a minimum of two files is needed: *.TAB and *.DAT."
Le 2014-11-26 00:32, "Agrawal, Dinesh (NSN - IN/Kolkata) [via OSGeo.org] " < [hidden email] > a écrit :
I am unable to open one normal blank page itself, without any tab by double clicking over desktop QGIS icon.
As per my observation it is just like capability related issue.
My laptop os is win7. And make of laptop is fisitgu make. Same is working over Dell make laptop with win7 os.
Dinesh Agrawal
+919804801421
-----Original Message-----
From: [hidden email]  [mailto: [hidden email] ] On Behalf Of ext Järnefelt Jouko
Sent: Tuesday, November 25, 2014 6:33 PM
To: [hidden email]
maybe your tab-file is corrupted? Does your other tab-files work properly? As workaround you could use Universal Translator in MapInfo and convert MapInfo Tab to Esri Shape (for example). Try opening this in QGIS.
Hope it helps!
Jouko
-----Alkuperäinen viesti-----
Lähettäjä:
[hidden email]  [mailto: [hidden email] ] Puolesta Agrawal, Dinesh (NSN - IN/Kolkata)
Lähetetty: 25. marraskuuta 2014 14:32
Vastaanottaja:
[hidden email] ;
[hidden email]
Aihe: Re: [Qgis-user] unable to open the QGIS Tab
HI,
I have loaded QGIS 2.4 also and run it on my system but still I am unable to open tab.
Dinesh Agrawal
+919804801421
From: [hidden email]  [mailto: [hidden email] ] On Behalf Of ext Alex Mandel
Sent: Friday, August 29, 2014 11:19 PM
To: [hidden email]
On 08/29/2014 05:42 AM, Paolo Cavallini wrote:
> Il 29/08/2014 14:20, Agrawal, Dinesh (NSN - IN/Kolkata) ha scritto:
>> Please suggest where I am doing mistake, my other friends are using this.
> Please, first of all upgrade to QGIS 2.4.
> All the best.
Well to be more clear, use the following links to download a newer version:
Standalone Installer
http://qgis.org/downloads/QGIS-OSGeo4W-2.4.0-1-Setup-x86.exe
OR OSGeo4w Installer
http://download.osgeo.org/osgeo4w/osgeo4w-setup-x86.exe
When in doubt always go to http://qgis.org  for your downloads.
Thanks,
Alex
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
[hidden email]
[hidden email]
[hidden email]
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/unable-to-open-the-QGIS-Tab-tp5159082p5174948.html
To start a new topic under Quantum GIS - User, email
[hidden email]
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context:
Re: unable to open the QGIS Tab
Sent from the
Quantum GIS - User mailing list archive  at Nabble.com.
[hidden email]
		http://osgeo-org.1560.x6.nabble.com/unable-to-open-the-QGIS-Tab-tp5159082p5174952.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/unable-to-open-the-QGIS-Tab-tp5159082p5174953.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141125/74eedcae/attachment.html>
