[Qgis-user] Lizmap - can't insert&update data in PostGis Views
Alexandre Neto senhor.neto at gmail.com
Wed Nov 26 02:11:36 PST 2014
On Wed, Nov 26, 2014 at 9:53 AM, Pedro VenĂ¢ncio <pedrongvenancio at gmail.com>
wrote:
> Hi Pedro,
> The database user that you are using in QGIS is the same that you are
> using in Lizmap? Or has the same privileges?
This must be the problem, the lizmap user must have trigger permission over
the tables.
> Best regards,
> Pedro VenĂ¢ncio
> 2014-11-26 9:49 GMT+00:00 Pedro <pedro.ferro at gmail.com>:
>> Thanks Alexandre and Sergio for yours insights.
>> My postgis views were built in way that is possible to make updates,
>> inserts
>> and deletes (through triggers) at the original tables.
>> Thats why I said that I make the same actions on the original project at
>> QGIS and it works fine.
>> The problem is that in Lizmap I can't make the same actions that I do at
>> QGIS with the postgis views. (it's a big problem for my project)
>> thanks,
>> Pedro
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/Lizmap-can-t-insert-update-data-in-PostGis-Views-tp5174737p5174991.html
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141126/cf0a4719/attachment.html>
