[Qgis-user] Lizmap - can't insert&update data in PostGis Views
Pedro Venâncio pedrongvenancio at gmail.com
Wed Nov 26 04:49:55 PST 2014
I do not know Lizmap, but I refer to the PostgreSQL user that Lizmap are
using to access the database (not the Lizmap user). This user is the same
that you are using in QGIS to access the database? This is because
PostgreSQL user must have permissions to run the triggers.
Best regards,
Pedro Venâncio
2014-11-26 12:23 GMT+00:00 Pedro <pedro.ferro at gmail.com>:
> Alexandre Neto wrote
> > On Wed, Nov 26, 2014 at 9:53 AM, Pedro Venâncio <
> > pedrongvenancio@
> > wrote:
> >> Hi Pedro,
> >> The database user that you are using in QGIS is the same that you are
> >> using in Lizmap? Or has the same privileges?
> > This must be the problem,
> > the lizmap user must have trigger permission over
> > the tables.
> I was searching for something like that at the user permissions in Lizmap
> and can't find it.
> Do you know what exact permissions should I enable/disable that ?
> thanks,
> Pedro
> http://osgeo-org.1560.x6.nabble.com/Lizmap-can-t-insert-update-data-in-PostGis-Views-tp5174737p5175030.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141126/107134b8/attachment.html>
