[Qgis-user] Crash of Grass and other plug-ins
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Wed Nov 26 08:09:23 PST 2014
You can start by Removing registry keys before hand and see if that helps. That will reset Qgis to its default state.
You could just do a fresh install removing (or backing up) everything from the .qgis2 folder.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
Le 2014-11-26 10:57, "Goran Granath [via OSGeo.org]" <ml-node+s1560n5175094h75 at n6.nabble.com> a écrit :
Hi!
I got curious the other day about QGIS 2.6 and installed it on my
desktop. I had 2.2 already installed sinc before. Everything went fine
except that the plug-ins stopped working, at least Grass did so. When I
start the 2.2 the following appears:
Kunde inte ladda insticksprogram processing på
grund av fel med classFactory() metoden
File
"C:/PROGRA~1/QGISVA~1/apps/qgis/./python\qgis\utils.py", line
204, in startPlugin
plugins[packageName] =
package.classFactory(iface)
File "C:/Users/G
ran/.qgis2/python/plugins\processing\__init__.py", line 37, in
classFactory
from processing.ProcessingPlugin import
ProcessingPlugin
File
453, in _import
mod = _builtin_import(name, globals, locals, fromlist,
level)
File "C:/Users/G
ran/.qgis2/python/plugins\processing\ProcessingPlugin.py", line 47,
in
if cmd_folder not in sys.path:
File
54, in showWarning
"warning:%s\ntraceback:%s" % (
warnings.formatwarning(message, category, filename, lineno), stk),
UnicodeDecodeError: 'ascii' codec can't decode byte 0xf6 in position 18:
ordinal not in range(128)
Python version:
2.7.5 (default, May 15 2013, 22:44:16) [MSC v.1500 64 bit
(AMD64)]
QGIS version:
2.2.0-Valmiera Valmiera, c3a2817
Python sökväg: ['C:/PROGRA~1/QGISVA~1/apps/qgis/./python',
u'C:/Users/G\xf6ran/.qgis2/python',
u'C:/Users/G\xf6ran/.qgis2/python/plugins',
'C:/PROGRA~1/QGISVA~1/apps/qgis/./python/plugins',
'C:\\PROGRA~1\\QGISVA~1\\bin\\python27.zip',
'C:\\PROGRA~1\\QGISVA~1\\apps\\Python27\\DLLs',
'C:\\PROGRA~1\\QGISVA~1\\apps\\Python27\\lib',
'C:\\PROGRA~1\\QGISVA~1\\apps\\Python27\\lib\\plat-win',
'C:\\PROGRA~1\\QGISVA~1\\apps\\Python27\\lib\\lib-tk',
'C:\\PROGRA~1\\QGISVA~1\\bin', 'C:\\PROGRA~1\\QGISVA~1\\apps\\Python27',
'C:\\PROGRA~1\\QGISVA~1\\apps\\Python27\\lib\\site-packages',
'C:\\PROGRA~1\\QGISVA~1\\apps\\Python27\\lib\\site-packages\\PIL',
'C:\\PROGRA~1\\QGISVA~1\\apps\\Python27\\lib\\site-packages\\win32',
'C:\\PROGRA~1\\QGISVA~1\\apps\\Python27\\lib\\site-packages\\win32\\lib',
'C:\\PROGRA~1\\QGISVA~1\\apps\\Python27\\lib\\site-packages\\Pythonwin',
'C:\\PROGRA~1\\QGISVA~1\\apps\\Python27\\lib\\site-packages\\Shapely-1.2.18-py2.7-win-amd64.egg',
'C:\\PROGRA~1\\QGISVA~1\\apps\\Python27\\lib\\site-packages\\six-1.3.0-py2.7.egg',
'C:\\PROGRA~1\\QGISVA~1\\apps\\Python27\\lib\\site-packages\\wx-2.8-msw-unicode',
'C:\\PROGRA~1\\QGISVA~1\\apps\\Python27\\lib\\site-packages\\xlrd-0.9.2-py2.7.egg',
'C:\\PROGRA~1\\QGISVA~1\\apps\\Python27\\lib\\site-packages\\xlwt-0.7.5-py2.7.egg',
'C:\\Users\\G\xf6ran\\.qgis2\\python\\plugins\\DigitizingTools\\tools']
The menu item "Geoprocessing" (Swedish) is also lacking,
so the use of plug-ins is seriously hampered.
When I start the versin 2.6 another message box appears:
File "D:/QGis2.6/apps/qgis/./python\qgis\utils.py", line
208, in startPlugin
plugins[packageName] = package.classFactory(iface)
File "C:/Users/G
classFactory
ProcessingPlugin
460, in _import
level)
File "C:/Users/G
in
55, in showWarning
Python version:
(AMD64)]
QGIS version:
2.6.0-Brighton Brighton, exported
Python sökväg: ['D:/QGis2.6/apps/qgis/./python',
'D:/QGis2.6/apps/qgis/./python/plugins',
'D:\\QGis2.6\\apps\\Python27\\lib\\site-packages\\matplotlib-1.3.1-py2.7-win-amd64.egg',
'D:\\QGis2.6\\apps\\Python27\\lib\\site-packages\\nose-1.3.3-py2.7.egg',
'D:\\QGis2.6\\apps\\Python27\\lib\\site-packages\\tornado-4.0.1-py2.7-win-amd64.egg',
'D:\\QGis2.6\\apps\\Python27\\lib\\site-packages\\backports.ssl_match_hostname-3.4.0.2-py2.7.egg',
'D:\\QGis2.6\\apps\\Python27\\lib\\site-packages\\certifi-14.05.14-py2.7.egg',
'D:\\QGis2.6\\bin\\python27.zip', 'D:\\QGis2.6\\apps\\Python27\\DLLs',
'D:\\QGis2.6\\apps\\Python27\\lib',
'D:\\QGis2.6\\apps\\Python27\\lib\\plat-win',
'D:\\QGis2.6\\apps\\Python27\\lib\\lib-tk', 'D:\\QGis2.6\\bin',
'D:\\QGis2.6\\apps\\Python27',
'D:\\QGis2.6\\apps\\Python27\\lib\\site-packages',
'D:\\QGis2.6\\apps\\Python27\\lib\\site-packages\\PIL',
'D:\\QGis2.6\\apps\\Python27\\lib\\site-packages\\jinja2-2.7.2-py2.7.egg',
'D:\\QGis2.6\\apps\\Python27\\lib\\site-packages\\markupsafe-0.23-py2.7-win-amd64.egg',
'D:\\QGis2.6\\apps\\Python27\\lib\\site-packages\\pytz-2012j-py2.7.egg',
'D:\\QGis2.6\\apps\\Python27\\lib\\site-packages\\win32',
'D:\\QGis2.6\\apps\\Python27\\lib\\site-packages\\win32\\lib',
'D:\\QGis2.6\\apps\\Python27\\lib\\site-packages\\Pythonwin',
'D:\\QGis2.6\\apps\\Python27\\lib\\site-packages\\Shapely-1.2.18-py2.7-win-amd64.egg',
'D:\\QGis2.6\\apps\\Python27\\lib\\site-packages\\six-1.3.0-py2.7.egg',
'D:\\QGis2.6\\apps\\Python27\\lib\\site-packages\\wx-2.8-msw-unicode',
'D:\\QGis2.6\\apps\\Python27\\lib\\site-packages\\xlrd-0.9.2-py2.7.egg',
'D:\\QGis2.6\\apps\\Python27\\lib\\site-packages\\xlwt-0.7.5-py2.7.egg',
I installed the 2.6 on another hard disk (D:) on my desktop. The
same problems apply to 2.6 as well.
My operating system is Windows 7.
So for the moment I use 2.2 on my laptop but I would love to have it back
on my desktop with its large screen and flash disk.
Thanks in advance
Göran Granath
Goran 'Joe' Granath, PhD Phone: +46-18-30
16 67
Ariadne Exploration AB E-mail:
[hidden email]
Malma Ringväg
1
www.ariadne.se
S-756 45 Uppsala
Sweden
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Crash-of-Grass-and-other-plug-ins-tp5175094.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Crash-of-Grass-and-other-plug-ins-tp5175094p5175098.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141126/0a099338/attachment.html>
