[Qgis-user] Labels with 'text'
Goyo
goyodiaz at gmail.com
Wed Nov 26 10:35:44 PST 2014
Removing decimals in the label formatting only works if the label is
actually a number, which is not anymore if you add the string "Acres".
So you need to explicitly apply some function on the field value,
something like
toint(acres) || ' Acres'
might do the trick.
Goyo
2014-11-26 18:45 GMT+01:00 Randal Hale <rjhale at northrivergeographic.com>:
> Question - I'm building a map for a client. I need to label a polygon with
> the Acres and the word Acres. The attribute for this polygon would be
> 184.35679835. In Properties -> Labels -> Formatting I can remove the
> decimals and I get 184 for a label.
> If I add the word Acres to the label -> acres || ' Acres' I expect to see
> 184 Acres. Instead I see 184.35679835 Acres.
> Is there something I'm missing when adding text to a label? I think there
> probably is....but I'm drawing a blank.
> Ubuntu 14.04 QGIS 2.6
> I haven't had a chance to test in Windows 7 OSGEO Install.
> Randy
> Randal Hale
> North River Geographic Systems, Inc
> http://www.northrivergeographic.com
> 423.653.3611 rjhale at northrivergeographic.com
> twitter:rjhale http://about.me/rjhale
> http://www.northrivergeographic.com/spatial-connect
> Qgis-user mailing list
