[Qgis-user] [QGIS-user] Prompt for projection when importing	raster - QGIS 2.6
    Brett Adams
    badams at spinifexgeophysics.com.au
    Wed Nov 26 23:17:01 PST 2014
Nicolas,
Tried setting  "use project CRS" when CRS is not specified.  However I’m guessing there is a difference between unrecognised and not set.  So this didn’t help.
The TIF files are georeferenced. They load into Mapinfo with the correct projection so I’m confident the information is there.
I’ll need to read up on the processing plugin, its not something I’ve ever used.
I thought there was an option such that all imported raster data had to be defined on import?
BA
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Nicolas Cadieux
Sent: Thursday, 27 November 2014 10:16 AM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] [QGIS-user] Prompt for projection when importing raster - QGIS 2.6
In your default CSR options, set "use project CRS" when CRS is not specified.  The CSR may not be included in the .tif files even if it is georeferenced. You can probably use the processing plugin to batch that.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
Le 2014-11-26 20:45, "Brett Adams-2 [via OSGeo.org]" <[hidden email]> a écrit :
Hi Folks,
How do I set QGIS 2.6 to prompt for projection when importing a raster file with a projection it doesn’t recognise?
The TIF images are GDA94/MGA zone51 but for some reason it doesn’t always recognise the projection.    I know they can be reset later, but when theirs 20 images that gets a bit laborious.
Thanks
Brett
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
  _____
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/QGIS-user-Prompt-for-projection-when-importing-raster-QGIS-2-6-tp5175193.html
To start a new topic under Quantum GIS - User, email ml-node+[hidden email]
To unsubscribe from Quantum GIS - User, click here.
 <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml> NAML
  _____
View this message in context: Re: [QGIS-user] Prompt for projection when importing raster - QGIS 2.6 <http://osgeo-org.1560.x6.nabble.com/Re-QGIS-user-Prompt-for-projection-when-importing-raster-QGIS-2-6-tp5175200.html>
Sent from the Quantum GIS - User mailing list archive <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html>  at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141127/1a82b9b9/attachment.html>
