[Qgis-user] layer query with modulo (source File Geodatabase)
    Carlos Cerdán
    sig.upagu at gmail.com
    Fri Nov 28 05:37:41 PST 2014
Hi Torsten
That sentence is right, both for filter or for ruled based styling. Perhaps
"contour" is a text column...
Regards
Carlos Cerdán
2014-11-28 4:11 GMT-05:00 Torsten Lange <torsten.lange at mail.de>:
> Hi,
> I've loaded a big set of contour lines with 5 m stepping from an ArcGIS
> File Geodatabase. From time to time I need to modulo out the 5 m lines in
> the viewer (showing only 10 m steps). Given a column "contour" this should
> work (shouldn't it?):
> "contour" % 10 = 0
> However, it returns 0 lines with both, double or integer type. The column
> contains just values of xx0 and xx5.
> Thanks for any hint!
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141128/dfc6638a/attachment.html>
