[Qgis-user] Add WMS in QGIS gives an error with Map request failed [error:Host http not found url:http://http//
Strunck, Alexander GIZ PS
alexander.strunck at giz.de
Sun Nov 30 01:48:06 PST 2014
Dear list,
I posted this issue a while ago in the forum but did not get an answer.
I got an URL from a friend who is working with Oracle MapBuilder. http://[IP]:11188/mapviewer/wms I tried to get the service via ArcMap and it was working.
Then I tried my beloved QGIS and there is a problem. I get the connection running and all layers are shown in the "Add Layer(s) from a WM(T)S Server". I choose a layer and it gets integrated in the Layers window. But somehow there is no map. It is the same problem for all layers.
When I check the log Messages I can see the problem
url:http://http//[IP]/:11188/mapviewer/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&BBOX=35.02831983698249729,31.49752950471350132,35.04319025529049725,31.50711888517620096&SRS=EPSG:4326&WIDTH=982&HEIGHT=633&LAYERS=GT_BLOCKS_MB&STYLES=&FORMAT=image/png&DPI=120&MAP_RESOLUTION=120&FORMAT_OPTIONS=dpi:120&TRANSPARENT=TRUE]
The beginning of the URL is the problem
http://http//
and the part with the port
/:11188
How can I fix the problem???
Thank You
Alexander
Deutsche Gesellschaft fuer Internationale Zusammenarbeit (GIZ) GmbH;
Sitz der Gesellschaft Bonn und Eschborn/Registered offices Bonn and Eschborn, Germany;
Registergericht/Registered at Amtsgericht Bonn, Germany; Eintragungs-Nr./Registration no. HRB 18384 und/and Amtsgericht Frankfurt am Main, Germany; Eintragungs-Nr./Registration no. HRB 12394;
USt-IdNr./VAT ID no. DE 113891176;
Vorsitzender des Aufsichtsrats/Chairman of the Supervisory Board: Dr. Friedrich Kitschelt, Staatssekretaer/State Secretary;
Vorstand/Management Board: Tanja Goenner (Vorstandssprecherin/Chair of the Management Board), Dr. Christoph Beier (Stellv. Vorstandssprecher/Vice-Chair of the Management Board), Dr. Hans-Joachim Preuss, Cornelia Richter
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141130/4a62473d/attachment.html>
