[Qgis-user] Serial map from template composer. Working with QGIS 2.2, problems with QGIS 2.4
Nyall Dawson
nyall.dawson at gmail.com
Wed Oct 1 13:12:43 PDT 2014
On 02/10/2014 2:55 am, "Andrea Amparore" <andrea.amparore at gmail.com> wrote:
> Thanks Andreas!
> Actually I need to do it with a script, because the serial printing is a
part of a much more complex script.
> It works on QGIS 2.2, but on QGIS 2.4 it drives me crazy…
Two things:
- QgsMapRenderer is deprecated in 2.4 and above. You should update your
code to use the new replacement QgsMapSettings object.
- Why don't you try saving the XML templates from your script to qpt files
and then try loading them manually into QGIS? That might give you a better
idea where your script is breaking.
Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141002/f8e6c122/attachment.html>
