[Qgis-user] Errors in startup phase of qgis-dev should add to issue system ?
Andrea Peri
aperi2007 at gmail.com
Sat Oct 4 01:46:29 PDT 2014
The start is from the qgis.bat installed from osgeo4w. I never set any
variabile pythopath in window system.
As i know all the variablres used are set directly in qgis-dev.bat.
Perhaps an overlap done from other installed systems.
I search for it.
THX
A.
Il 04/ott/2014 10:25 "Luigi Pirelli" <luipir at gmail.com> ha scritto:
> the error is due to your installed modules
> as you can see: from osgeo import ogr.... No module named osgeo
> explain you have no osgeo python module installed or it can't be find
> in your PYTHONPATH. What did yuo changed in your previous qgis or
> environment installation?
> regards, Luigi Pirelli
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141004/305c16f4/attachment.html>
