[Qgis-user] [Qgis-developer] QLR relative vs absolute paths - opinions needed
Richard Duivenvoorde
rdmailings at duif.net
Mon Oct 6 00:10:38 PDT 2014
On 06-10-14 05:07, Nathan Woodrow wrote:
> Hey all,
> I would like to get some opinions on how the currently QLR feature in
> 2.4 works. Currently the QLR will have absolute paths if the project is
> set to have them, or relative if the project is set in that mode.
> I'm not sure I really like this as it's a bit magic with what you will
> get and means you can't make a relative QLR from a absolute path based
> project.
> Do you think this needs to be an option for each QLR when saving?
Hi Nathan,
I think absoluth path projects and relative projects(!) have different
use-cases. I prefer relative paths, but in organisations with one huge
data-disk, maybe absoluth paths are preferable so project/qlr files can
be moved around easily.
My idea is that one of both is preferred by a user, so one of the
options (relative/absolute) is more or less standard for that user.
Adding an extra option to switch (for a non 'standard' situation) adds
extra option stress. While if clearly documented (or shown in dialog)
that a relative project breeds relative QLR files and vv can be enough?
Then IF a user want a custom type of QLR he/she can create a temp
project for it, change that to the preferred option and create a qlr
with that....
So my stand: keep the dialogs simple (for most common use cases),
especially as there is already a way to do the thing you want to keep an
option for.
See what others think of this.
Regards,
