[Qgis-user] Qgis mobile viewer
Martin Baloga
matobaloga at gmail.com
Mon Oct 6 22:25:41 PDT 2014
Problem solved. Wrong coordinates. Is there any possibility to setup center
if map for each topic? Or automatic zoom to extent by changing topic?
Thank you
Martin
Dňa 6.10.2014 17:32 používateľ "Martin Baloga" <matobaloga at gmail.com>
napísal:
> Hi,
> Are there any guidelines to setup mobile viewer for qgis server? I changed
> the epsg to 3856 and extent. Write the url for topic with service and map
> parameters. Mobile viewer shows the toc but nothing on map... Any
> suggestions?
> The qgis web client works with that map as well as GetCapabilties works
> with the wms.
> Thank you.
> Martin
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141007/e4e15329/attachment.html>
