[Qgis-user] Copying / pasting polygons between layers?
Andre Joost
andre+joost at nurfuerspam.de
Wed Oct 8 20:52:25 PDT 2014
Am 08.10.2014 21:18, schrieb Luciano:
> the following error:
> *Errors in the provider: OGR Error creating feature -38: Attempt to
> write non-point (MULTIPOINT) geometry to point shapefile *".
> This occurs when I copy points from a shapefile layer and neck in another
> shapefile layer.
> Note: The two layers are points, do not understand why this 'MULTPOINT'
Could be this bug:
https://hub.qgis.org/issues/10747
which should be fixed in latest QGIS-dev version. The upcoming QGIS 2.6
should work as expected.
HTH,
André Joost
