[Qgis-user] Zoom does not go smaller than 1:2.256
steff_f
stefaniefa at web.de
Thu Oct 9 00:00:26 PDT 2014
Hello André!
You are completely right! it works as you say!
Thanks for the quick help!
Best regards, Steffi
On 8 October 2014 17:01, Andre Joost [via OSGeo.org] <
ml-node+s1560n5166510h48 at n6.nabble.com> wrote:
> Am 08.10.2014 11:03, schrieb steff_f:
> > Hello everybody!
> > I have searched several times the web for my problem, but havn´t found
> any
> > solution so far. In case, there is already one, please let me know.
> > Since some time I realized, that I can´t zoom closer than 1:2.256. QGIS
> > ignores the fixed zoom-scales and always zoomes to multipliers of this
> > 2.256, but never smaller than this.
> > In the Layout-View it is possible to go closer.
> > I am pretty sure, there is no installed extension which could have
> caused
> > this problem.
> > Even a deinstallation hasn´t fixed the problem.
> You might have installed the TileMapScale Plugin. That has predfined
> zoom levels, starting at 1:2256 (corresponding to some google/OSM Tile
> level).
> Either deactivate the plugin, or uncheck the "activate zoomlevels"
> checkbox of the plugin panel.
> HTH,
> André Joost
> Qgis-user mailing list
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5166510&i=0>
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/Zoom-does-not-go-smaller-than-1-2-256-tp5166440p5166510.html
> To unsubscribe from Zoom does not go smaller than 1:2.256, click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5166440&code=c3RlZmFuaWVmYUB3ZWIuZGV8NTE2NjQ0MHwxMDc4MzQ2MzEx>
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Zoom-does-not-go-smaller-than-1-2-256-tp5166440p5166598.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141009/c65d0509/attachment.html>
