[Qgis-user] Help QGIS main window higer than the disply (1200 x 1920)
Salvatore Larosa
lrssvtml at gmail.com
Mon Oct 13 03:08:30 PDT 2014
On Mon, Oct 13, 2014 at 11:57 AM, Johan Nilsson <joni8135 at gmail.com> wrote:
> If I start from terminal I get this errorrs
> Johan at Datorn:~$ qgis
> Warning: loading of qt translation failed
> [/usr/share/qt4/translations/qt_en_US]
> Warning: QGraphicsScene::addItem: item has already been added to this scene
> no need
> ***************** deactivate parallellinetool
> ***************** deactivate circulararctool
> ***************** deactivate modifycirculararctool
> I have now find that only then i click on the main-window (don't need to
> resize), the window get bigger than the display/screen :(
I guess the problem is due to some plugin you are using, try to
deactivate plugins in order to see if the problem disappear.
Regards,
-SL
Salvatore Larosa
linkedIn: http://linkedin.com/in/larosasalvatore
twitter: @lrssvt
skype: s.larosa
IRC: lrssvt on freenode
