[Qgis-user] Multiple QGIS installs (Windows)
McDonaldR
McDonaldR at angus.gov.uk
Mon Oct 13 06:07:50 PDT 2014
Hi Jonathan
Yes, you can.
You can install the standalone version - it installs into a unique folder under C:\Program Files\
You can install using OSGeo4W and install the latest stable and development releases into OSGeo4W\apps\qgis and qgis-dev
However, having said this all installs (I have 2.0.1, 2.2 and 2.4 and 2.5dev installed) use the same .qgis2 folder in your user directory. So plugins that work for 2.2 but not 2.4 will show up as broken when using 2.4 but will work in 2.2. I am not sure how you can separate out the configs to have separate folders or each install. Maybe some env variable?
Cheers
Ross
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Jonathan Moules
Sent: 13 October 2014 14:02
To: 'qgis-user'
Subject: [Qgis-user] Multiple QGIS installs (Windows)
Hi list,
I was wondering, is it possible to have multiple installs of QGIS at the same time on a Windows box?
I.e.:
2.2
2.4
2.6 (in a month)?
Or can you only have one? And does the answer vary depending on whether you're using the OSGeo installer or the standalone one?
Cheers,
Jonathan
HR Wallingford and its subsidiaries uses faxes and emails for confidential and legally privileged business communications. They do not of themselves create legal commitments. Disclosure to parties other than addressees requires our specific consent. We are not liable for unauthorised disclosures nor reliance upon them.
If you have received this message in error please advise us immediately and destroy all copies of it.
HR Wallingford Limited
Howbery Park, Wallingford, Oxfordshire, OX10 8BA, United Kingdom
Registered in England No. 02562099
This message is strictly confidential. If you have received this in error, please inform the sender and remove it from your system. If received in error you may not copy, print, forward or use it or any attachment in any way. This message is not capable of creating a legal contract or a binding representation and does not represent the views of Angus Council. Emails may be monitored for security and network management reasons. Messages containing inappropriate content may be intercepted. Angus Council does not accept any liability for any harm that may be caused to the recipient system or data on it by this message or any attachment.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141013/ac22f03c/attachment.html>
