[Qgis-user] QuickOSM, a QGIS plugin to query Overpass
Stefan Keller
sfkeller at gmail.com
Thu Oct 16 06:06:07 PDT 2014
Salut Etienne
Cool plugin!
There are other Overpass instances around, like http://overpass.osm.ch/api .
So it would be useful to configure them.
I've seen that you have the information put statically into the code at
<user>\.qgis2\python\plugins\QuickOSM\ui\main_window.py
self.comboBox_default_OAPI.setItemText(0,
_translate("ui_main_window", "http://www.overpass-api.de/api/", None))
self.comboBox_default_OAPI.setItemText(1,
_translate("ui_main_window", "http://overpass.osm.rambler.ru/cgi/",
None))
self.comboBox_default_OAPI.setItemText(2,
_translate("ui_main_window", "http://api.openstreetmap.fr/oapi/",
None))
It would be nice to have this in the Parameters section - or at least
as a parameter in osmconf.ini
(<user>\.qgis2\python\plugins\QuickOSM\osmconf.ini)
A2, S.
2014-10-16 15:01 GMT+02:00 Etienne Trimaille <etienne.trimaille at gmail.com>:
> The internship is finished since the 1.0 release.
> 1.1 has been released thanks to my free time on the project.
> A lot of tickets are still open so, I'll try to continue improving quickosm
> as far as I can.
> But contributors are welcome too :)
> 2014-10-16 8:52 GMT+02:00 Paolo Cavallini <cavallini at faunalia.it>:
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> Bonjour Etienne,
>> Il 15/10/2014 19:10, Etienne Trimaille ha scritto:
>> > For those who do not already know, a QGIS plugin exists so as to
>> > run an overpass query.
>> > This plugin is QuickOSM which you can find in the QGIS's repository
>> > I've developped this project during my internship at 3Liz :
>> > http://www.3liz.com/
>> Thanks for this. Do you have any plan fro longer term maintenance of
>> this plugin? It would be good to have finally a stable, easy to use,
>> solution for the interface with OSM.
>> Amicalement.
>> Paolo Cavallini - www.faunalia.eu
>> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1
>> iEYEARECAAYFAlQ/ayYACgkQ/NedwLUzIr7BCgCgoz6exq/7xLvH7LR8uXXrh3lf
>> rI4AnjPlc6tRdJoGYQHQN42TiiYhG2lL
>> =OXTI
>> -----END PGP SIGNATURE-----
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
