[Qgis-user] qgis chugiak reshape features tool doesn't work
Luigi Pirelli luipir at gmail.com
Mon Oct 20 01:49:06 PDT 2014
Hi umerto,
I worked on that blocker issue with Arnoud in the last Hackmeeting in
Essen... we found a solution that has not been merged yet
(https://github.com/qgis/QGIS/pull/1609). I post this answer to Jürgen
Fisher too, to "press" him to merge the pull request.
The problem raise at low level scale due the algorithm to find points
that intersects polygon and when the reshape line points are too near
the border.
conseguent to this error, is that the reshape tool remain active and
it's difficult to exit from reshaping... this was an unexpected
behaviour that wasn't catched.
Use case is generally archeological user that works with that level of scale.
waiting for the 2.6 release I suggest you to find a workaround, just
reshape at higher scales and/or setting the reshape line not so near
the polygon border (if it make sense)
Another workaround is changing the projection to work to higher scale.
regards, Luigi Pirelli
On 20 October 2014 10:25, umbertofilippo <umbertofilippo at tiscali.it> wrote:
> Hello.
> I’ve been using qgis since a long time.
> With the new version (2.4) I can’t edit my polygons with the reshape
> features tool because it rises an “unknown exception”.
> I know this is a bug (see hub.qgis.org). Anyway, it seems they are trying to
> fix this problem (on GitHub), but, as a non-programmer user, I cannot figure
> out if I can actually solve my issue modifying the code myself (according to
> the gits) so far.
> Since the reshape tool is a must to have tool in my work, I wonder if
> someone experienced the same lack and maybe got a hint for me.
>  Thanks in advance!
> P.S.: I am really sorry to have posted this message many times by my second
> (not-registered) mail address (umberto.minora at unimi.it). Please consider
> this message and not the others, and sorry again...
> Qgis-user mailing list
