[Qgis-user] Composer - legend & attribute table HELP
Junior Delaz
delazj at gmail.com
Mon Oct 20 06:26:34 PDT 2014
Actually, it is already present in dev version.
After you added an attribute table in your composer, in its properties tab,
there is the ability to "add frame". Adding new frame helps you organize
the way you present your attribute data according to the size of each frame.
Regards,
2014-10-20 15:08 GMT+02:00 skampus <skampus at gmail.com>:
> Nyall Dawson wrote
> > On 07/07/2014 8:28 am, "skampus" <
> > skampus@
> > > wrote:
> >> hi, two simple questions about composer, hoping there's a solution for
> > them.
> >> 1) is there the possibility to split inserted attribute table in two
> > columns
> >> as for the legend? i have almost 100 records having only two field so if
> > i'd
> >> have two columns in composer i could insert all the table just in same
> > page
> > Not yet. This may be addressed in the 2.6 release though.
> hi, will this option be present in 2.6?
> actually it seems there is not in dev version.
> thank you all and ciao
> s.
> http://osgeo-org.1560.x6.nabble.com/Composer-legend-attribute-table-HELP-tp5149866p5168404.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141020/2411f503/attachment.html>
