[Qgis-user] Export WKT format
Alex Mandel tech_dev at wildintellect.com
Mon Oct 20 10:26:58 PDT 2014
That sounds like it's hitting some sort of line limit. Might be a bug in
OGR. You could try writing WKT to a column first, but it would have to
be in a layer type that supports long text fields.
That said WKT is not a great format for complex geometries. Perhaps you
can tell us your goal and we can suggest another way to get there.
Thanks,
Alex
On 10/20/2014 10:21 AM, Andrew Gillett wrote:
> Thanks for the info. I've just tried this and there appears to be a bug
> in it. I'm using the country border data from here:
> http://www.naturalearthdata.com/downloads/10m-cultural-vectors/
> If, for example, I select Iceland and export as you suggested, the
> column for the polygon data is truncated. Only about 200 vertices are
> exported, as compared to around 3000 which are correctly present if I
> use the copy/paste method. The polygon data ends with an X coordinate
> but no Y coordinate, and the closing brackets and quote mark are also
> missing.
> On 20/10/2014 17:39, Matthias Kuhn wrote:
>> Hi Andrew,
>> WKT is a format for geometries and not a file type. Therefore it is not
>> possible to offer a save as WKT just like that. You can however easily
>> choose Comma Separated Value as export format and then choose AS_WKT in
>> the Geometry combobox under layer options.
>> Best regards,
>> Matthias
>> On 20.10.2014 18:35, Andrew Gillett wrote:
>>> It is possible to export in WKT format by copying then pasting into a
>>> text editor. However, there is no WKT option when exporting via Layer
>>> -> Save As. Is there a particular reason for this, or is there a
>>> development list where I could request this?
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
