[Qgis-user] Georeferencer not working after installing 2.4
Thomas Stanley-Jones
tstanleyjones at gmail.com
Tue Oct 21 06:55:02 PDT 2014
Thank you for your input, I'll give these a try when I get home. I had
tried to uninstall and reinstall QGIS, but it seemed to have kept my
settings (window positions, recent projects, etc...). Although I probably
won't need it this time, how would I remove these user settings? I found
this suggestion,
http://lists.osgeo.org/pipermail/qgis-user/2012-March/016149.html, but
wondered if that was more than was necessary.
Thanks again!
Thomas
On Tue, Oct 21, 2014 at 8:29 AM, Richard Duivenvoorde <rdmailings at duif.net>
wrote:
> On 21-10-14 14:37, giulianc51 wrote:
> > Hi Richard,
> > thanks for your attention to our work, but .... I think Thomas is
> > referring to
> >>> Since then when I choose Raster --> Georeferencer, nothing
> > raster georeferencer :-)
> Mmm, ah, you are right, I got your plugin from his backtrace error:
> File "C:/Users/sj_family/.qgis2/python/plugins\vectGeoref\__init__.py",
> line 26, in classFactory
> from vectorgeoref import VectorGeoref
> And I was able to reproduce the error...
> Sorry for the noise.
> @Thomas: the Raster georeferencer should just be there.
> One thing that comes to my mind, is that you have set it as a docked
> widget (via it's 'Configure Georeferencer/Show Georeferencer window
> docked') and then closed the panel. So it's there but you closed it. Try
> to make it visible again via either:
> - View/Panels/Georeferencer
> or
> - right click somewhere on the menu en select it there
> Regards,
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141021/cfff37d0/attachment.html>
