[Qgis-user] [QGIS-pt] error in XML qgis layer style
Luigi Pirelli
luipir at gmail.com
Tue Oct 21 08:51:44 PDT 2014
try to explain your procedural steps and paste data to reproduce the use case.
regards, Luigi Pirelli
On 21 October 2014 15:26, Pedro Costa <pedrocostaarma at sapo.pt> wrote:
> I am using qgis but also tried with a query.
> I add what you said but do not work to.
> Em 21-10-2014 09:12, Luigi Pirelli escreveu:
>> are you saving using sql or qgis functionalities? it seems you have an
>> already prepared XML and you want to insert in postgres styles table
>> using sql. If it so, add
>> SET XML OPTION DOCUMENT;
>> before the update or insert statement
>> On 21 October 2014 09:57, Pedro Costa <pedrocostaarma at sapo.pt> wrote:
>>> Sorry I write it in portuguese by mistake.
>>> I'm trying to save a qgis style in postgresql database but i receive this
>>> error.
>>> I think it's an error on XML document and tried to find in XML validator
>>> but
>>> i get no errors.
>>> Any tip about how to fix that or what is the problem?
>>> Thanks
>>> Em 21-10-2014 08:38, Luigi Pirelli escreveu:
>>>> are you trying to restore a pgdump?
>>>> estas probando a reimportar un dump de postgres?
>>>> a presto Luigi Pirelli
>>>> 2014-10-20 18:26 GMT+02:00 Pedro Costa <pedrocostaarma at sapo.pt>:
>>>>> Boa tarde pessoal,
>>>>> Estou a tentar gravar um ficheiro de estilo numa BD postgres mas recebo
>>>>> o
>>>>> seguinte erro na query:
>>>>> ERRO: invalid XML document
>>>>> DETAIL: Entity: line 1: parser error : Unfinished System or Public ID
>>>>> or
>>>>> ' expected
>>>>> <!DOCTYPE qgis PUBLIC "http://mrcc.com/qgis.dtd" "SYSTEM">
>>>>> Pelos vistos é um erro no documento XML do INSERT da query:
>>>>> INSERT INTO (...)
>>>>> XMLPARSE(DOCUMENT
>>>>> '<!DOCTYPE qgis PUBLIC ''http://mrcc.com/qgis.dtd'' ''SYSTEM''>
>>>>> <qgis version="2.4.0-Chugiak" minimumScale="-4.65661e-10"
>>>>> maximumScale="1e+08" simplifyDrawingHints="0" minLabelScale="0"
>>>>> maxLabelScale="1e+08" simplifyDrawingTol="1" simplifyMaxScale="1"
>>>>> hasScaleBasedVisibilityFlag="0" simplifyLocal="1"
>>>>> scaleBasedLabelVisibilityFlag="0">
>>>>> <renderer-v2 symbollevels="0" type="singleSymbol">...
>>>>> Alguém já se deparou com ele ou tem uma dica para o contornar? Já
>>>>> coloquei
>>>>> no XML Validator que não encontrou nada.
>>>>> OS Win7 64 bits
>>>>> Qgis 2.4
>>>>> Abraços
>>>>> _______________________________________________
>>>>> QGIS-pt mailing list
>>>>> QGIS-pt at lists.osgeo.org
>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/qgis-pt
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
