[Qgis-user] Vectors data and raster with same projection didnot overlap
Yada Elisabeth
yadaelisabeth at gmail.com
Wed Oct 22 10:35:30 PDT 2014
I follow many methods (exploring differents tutorials documents):
1- I set the in one project properties under CRS: EPSG:32631 -WGS 84 / UTM
zone 31 N and open my layers
2- for the second project, I Rightclick -> "Set CRS for layer"
3- I tried the both (project properties and rightclick)
Thanks
2014-10-22 15:16 GMT+00:00 Andre Joost <andre+joost at nurfuerspam.de>:
> Am 22.10.2014 um 15:11 schrieb Yada Elisabeth:
>> Dear Mark,
>> the vectors data are basemaps with this CRS:
>> PROJCS["WGS_1984_Web_Mercator_Auxiliary_Sphere",GEOGCS["GCS_
>> WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,
>> 298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",
>> 0.0174532925199433]],PROJECTION["Mercator_Auxiliary_Sphere"],PARAMETER["
>> False_Easting",0.0],PARAMETER["False_Northing",0.0],
>> PARAMETER["Central_Meridian",0.0],PARAMETER["Standard_
>> Parallel_1",0.0],PARAMETER["Auxiliary_Sphere_Type",0.0],
>> UNIT["Meter",1.0]]
>>>> I have a set of vector data and raster data I reproject in the same CRS
>>>> (EPSG:32631 ;
> How did you reproject the vector data to EPSG:32631?
> Rightclick -> "Set CRS for layer" is NOT the right way to do it.
> Greetings,
> André Joost
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141022/74066092/attachment.html>
