[Qgis-user] question regarding linking Algorithms in Graphical Modeler
Victor Olaya
volayaf at gmail.com
Mon Oct 27 11:55:48 PDT 2014
that " [Errno 9] Bad file descriptor" is usually caused by a print
statement trying to print to the console while the console is closed.
Opening the Python console should let you run the model. Sounds to me like
a debug line that was committed and not removed later
Anyway, it should be fixed in the current version, but i will check and
remove any debug line in case there are still in the code
Hope this helps
2014-10-27 19:37 GMT+01:00 Martin Schneppmüller <mstrms2000 at gmail.com>:
> Hi Carl,
> I have the same problem for different modells made with QGIS 2.2 and QGIS
> 2.4.
> I think it is a problem with the processing plugin and I hope it will be
> solved with QGIS 2.6
> <Hi, I'm running QGIS 2.4.0-Chugiak on a Windows & machine, and I'm new to
> QGIS.
> <I'm trying run a model that has three algorithms, two of which are run in
> "parallel" and a third that <uses the outputs from form the first two. I
> specified that that third The first algorithm runs fine but <when it gets
> to the second it bombs with the message:
> < C:\PROGRA~1\QGISCH~1\bin>exit
> < Converting outputs
> < Outputs: outfile =E:/temp/PreNBR7.tif
> < OK. Execution took 49.503 ms (1 outputs).
> < Prepare algorithm 1: r.mapcalculator - Calculate new raster map
> from a r.mapcalc <expression.
> < [Errno 9] Bad file descriptor See log for more details
> <The three pieces work fine when broken into separate models but I would
> like to have the whole <thing run in one go..
> <I exported to a script (below) and have attached the model.
> http://www.halberstadt.de/
> http://www.domverein-halberstadt.de/
> http://www.dom-und-domschatz.de/
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141027/8d085ad7/attachment.html>
